[Swift-devel] Re: coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May  1 14:09:58 CDT 2009
No, globus-job-run failed
ERROR: Failed to connect to local queue manager
CEDAR:6001:Failed to connect to <128.135.92.83:32796>
GRAM Job failed because the job failed when the job manager attempted to
run it (error code 17)
So, in this case could we tell that it is a GLOBUS issue, which means we
need to contact the support team?
zhao
Mihael Hategan wrote:
> On Fri, 2009-05-01 at 14:01 -0500, Zhao Zhang wrote:
>> Hi, Mike
>> I got an error when I rerun the test with coaster on teraport. Any ideas
>> for this error?
> Does a simple globusrun work (make sure it's not a fork job)?
>> [zzhang at tp-grid1 sites]$ ./run-site
>> coaster/gwynn-coaster-gram2-gram2-condor.xml
>> testing site configuration: coaster/gwynn-coaster-gram2-gram2-condor.xml
>> Removing files from previous runs
>> Running test 061-cattwo at Fri May 1 13:46:37 CDT 2009
>> Swift 0.9rc2 swift-r2860 cog-r2388
>> RunID: 20090501-1346-ge8hz8r7
>> Progress:
>> Progress:  Stage in:1
>> Progress:  Submitting:1
>> Progress:  Submitted:1
>> Failed to transfer wrapper log from
>> 061-cattwo-20090501-1346-ge8hz8r7/info/4 on teraport
>> Progress:  Active:1
>> 061-cattwo-20090501-1346-ge8hz8r7/info/6 on teraport
>> Progress:  Active:1
>> 061-cattwo-20090501-1346-ge8hz8r7/info/8 on teraport
>> Progress:  Failed:1
>> Execution failed:
>>         Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: teraport
>> Directory: 061-cattwo-20090501-1346-ge8hz8r7/jobs/8/cat-863f47aj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>         Failed to start worker:
>> null
>> null
>> org.globus.gram.GramException: The job failed when the job manager
>> attempted to run it
>>         at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>         at java.lang.Thread.run(Thread.java:595)
>> Cleaning up...
>> Shutting down service at https://128.135.92.83:46035
>> Got channel MetaChannel: 665483948 -> GSSSChannel-null(1)
>> - Done
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> zhao
