[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 14:07:45 CDT 2009
On Fri, 2009-05-01 at 14:01 -0500, Zhao Zhang wrote:
> Hi, Mike
> I got an error when I rerun the test with coaster on teraport. Any ideas
> for this error?
Does a simple globusrun work (make sure it's not a fork job)?
> [zzhang at tp-grid1 sites]$ ./run-site
> coaster/gwynn-coaster-gram2-gram2-condor.xml
> testing site configuration: coaster/gwynn-coaster-gram2-gram2-condor.xml
> Removing files from previous runs
> Running test 061-cattwo at Fri May 1 13:46:37 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090501-1346-ge8hz8r7
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Failed to transfer wrapper log from
> 061-cattwo-20090501-1346-ge8hz8r7/info/4 on teraport
> Progress:  Active:1
> 061-cattwo-20090501-1346-ge8hz8r7/info/6 on teraport
> Progress:  Active:1
> 061-cattwo-20090501-1346-ge8hz8r7/info/8 on teraport
> Progress:  Failed:1
> Execution failed:
>         Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: teraport
> Directory: 061-cattwo-20090501-1346-ge8hz8r7/jobs/8/cat-863f47aj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Failed to start worker:
> null
> null
> org.globus.gram.GramException: The job failed when the job manager
> attempted to run it
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:595)
> Cleaning up...
> Shutting down service at https://128.135.92.83:46035
> Got channel MetaChannel: 665483948 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> zhao
