[Swift-devel] coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May  1 14:01:31 CDT 2009
Hi, Mike
I got an error when I rerun the test with coaster on teraport. Any ideas
for this error?
[zzhang at tp-grid1 sites]$ ./run-site
coaster/gwynn-coaster-gram2-gram2-condor.xml
testing site configuration: coaster/gwynn-coaster-gram2-gram2-condor.xml
Removing files from previous runs
Running test 061-cattwo at Fri May 1 13:46:37 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090501-1346-ge8hz8r7
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Failed to transfer wrapper log from
061-cattwo-20090501-1346-ge8hz8r7/info/4 on teraport
Progress:  Active:1
061-cattwo-20090501-1346-ge8hz8r7/info/6 on teraport
Progress:  Active:1
061-cattwo-20090501-1346-ge8hz8r7/info/8 on teraport
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: teraport
Directory: 061-cattwo-20090501-1346-ge8hz8r7/jobs/8/cat-863f47aj
stderr.txt:
stdout.txt:
Caused by:
        Failed to start worker:
null
null
org.globus.gram.GramException: The job failed when the job manager
attempted to run it
        at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
        at org.globus.gram.GramJob.setStatus(GramJob.java:184)
        at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
        at java.lang.Thread.run(Thread.java:595)
Cleaning up...
Shutting down service at https://128.135.92.83:46035
Got channel MetaChannel: 665483948 -> GSSSChannel-null(1)
- Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
zhao
