[Swift-devel] Re: Regular Test of Coaster and Condor-g
    Ben Clifford
    benc at hawaga.org.uk
    Mon May  4 04:29:33 CDT 2009
On Fri, 1 May 2009, Zhao Zhang wrote:
> Ben, could you help me tell what the difference there is? I ran the
> exactly same thing.
You need to look at each site individually and see what the errors are for
each one.
The sites test code does not keep logs for each site, although you could
modify it to do so, so you need to run a broken site individually by using
the run-site test command, and then look at what the cause of failure for
that site is.
