[Swift-devel] lots of variable not found
    Ben Clifford
    benc at hawaga.org.uk
    Sun Mar 22 06:28:19 CDT 2009
I've seen these sporadically in the past but there seem to be more of them
happening in the nmi build and test recently.
On
http://nmi-s005.cs.wisc.edu:80/nmi/index.php?page=results/runDetails&runid=140131
the 066-many test fails with
Progress:  Selecting site:1021 Active:1 Stage out:1 Finished
successfully:1596
Execution failed:
	Variable not found: #channel#restartout
and again in here:
http://nmi-s005.cs.wisc.edu:80/nmi/index.php?page=results/runDetails&rows=20&&runid=140127&offset=20&rows=20
on nmi_cent_4.2
and a
successfully:1867
Execution failed:
	Variable not found: #threadcount
in 066-many on x86_suse_10 in that same URL above.
I've also seen:
  Event was No #caller found on stack for sys:sequential @ 066-many.kml,
  line: 35
on NMI's x85_slf_3 platform, again in 066-many.
These all have the feel of something racy in Karajan, and are hopefully
relatively easy to reproduce (i.e. run 066-many tens of times and you
should get).
On the jdk 1.4 test that ran last night, 3 out of the 13 runs that have
completed as of my writing this mail failed. Thats over 20% which is an
uncomfortably high failure rate.
