[Swift-devel] hprof profiling of coaster services
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 19 14:43:48 CDT 2009
How many jobs did this run have?
Did you observe a high cpu load on the head node while it was running?
On Fri, 2009-06-19 at 13:42 -0500, Mihael Hategan wrote:
> I'm looking for a complete trace (make sure you use cpu=times) in binary
> format (format=b) that I can load and analyze in some profiler.
> The think below says that waiting takes time. Which is not interesting
> because at the same time waiting doesn't eat CPU.
> On Fri, 2009-06-19 at 13:27 -0500, Allan Espinosa wrote:
> > profile trace is in run02/java.hprof.txt
> > summary:
> > CPU SAMPLES BEGIN (total = 19493) Fri Jun 19 13:22:27 2009
> > rank   self  accum   count trace method
> >    1 48.99% 48.99%    9550 300225 java.net.PlainSocketImpl.socketAccept
> >    2 25.08% 74.07%    4888 300411 java.lang.UNIXProcess.waitForProcessExit
> >    3 25.07% 99.14%    4887 300487
> > org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run
> >    4  0.18% 99.32%      36 300465 java.net.SocketInputStream.socketRead0
> >    5  0.09% 99.42%      18 300472 java.net.SocketInputStream.socketRead0
> >    6  0.05% 99.46%       9 300051 java.lang.ClassLoader.defineClass1
> >    7  0.02% 99.48%       4 300498 java.lang.Shutdown.halt0
> >    8  0.02% 99.50%       3 300101 java.lang.ClassLoader.findBootstrapClass
> >    9  0.02% 99.51%       3 300123 java.util.zip.ZipFile.getEntry
> >   10  0.02% 99.53%       3 300492 java.io.FileInputStream.available
> >   11  0.01% 99.54%       2 300433 COM.claymoresystems.cert.CertContext.<clinit>
> >   12  0.01% 99.55%       2 300435 java.io.FileInputStream.open
> >   13  0.01% 99.56%       2 300447 java.lang.Throwable.fillInStackTrace
> >   14  0.01% 99.57%       2 300460 java.util.zip.Inflater.inflateBytes
> >   15  0.01% 99.58%       2 300491 java.lang.Throwable.fillInStackTrace
> > CPU SAMPLES END
> > -Allan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
