[Swift-devel] hprof profiling of coaster services
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 19 13:42:31 CDT 2009
I'm looking for a complete trace (make sure you use cpu=times) in binary
format (format=b) that I can load and analyze in some profiler.
The think below says that waiting takes time. Which is not interesting
because at the same time waiting doesn't eat CPU.
On Fri, 2009-06-19 at 13:27 -0500, Allan Espinosa wrote:
> profile trace is in run02/java.hprof.txt
> summary:
> CPU SAMPLES BEGIN (total = 19493) Fri Jun 19 13:22:27 2009
> rank   self  accum   count trace method
>    1 48.99% 48.99%    9550 300225 java.net.PlainSocketImpl.socketAccept
>    2 25.08% 74.07%    4888 300411 java.lang.UNIXProcess.waitForProcessExit
>    3 25.07% 99.14%    4887 300487
> org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run
>    4  0.18% 99.32%      36 300465 java.net.SocketInputStream.socketRead0
>    5  0.09% 99.42%      18 300472 java.net.SocketInputStream.socketRead0
>    6  0.05% 99.46%       9 300051 java.lang.ClassLoader.defineClass1
>    7  0.02% 99.48%       4 300498 java.lang.Shutdown.halt0
>    8  0.02% 99.50%       3 300101 java.lang.ClassLoader.findBootstrapClass
>    9  0.02% 99.51%       3 300123 java.util.zip.ZipFile.getEntry
>   10  0.02% 99.53%       3 300492 java.io.FileInputStream.available
>   11  0.01% 99.54%       2 300433 COM.claymoresystems.cert.CertContext.<clinit>
>   12  0.01% 99.55%       2 300435 java.io.FileInputStream.open
>   13  0.01% 99.56%       2 300447 java.lang.Throwable.fillInStackTrace
>   14  0.01% 99.57%       2 300460 java.util.zip.Inflater.inflateBytes
>   15  0.01% 99.58%       2 300491 java.lang.Throwable.fillInStackTrace
> CPU SAMPLES END
> -Allan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
