[Swift-devel] hprof profiling of coaster services
Allan Espinosa
aespinosa at cs.uchicago.edu
Fri Jun 19 14:52:14 CDT 2009
it has 200 jobs using the vanilla 066-many.swift workflow.
yes. cpu usage indicates 100-200 % utilization in the duration of the
workflow. I made a script(1) recording of the top session and
attached it in this email.
-Allan
2009/6/19 Mihael Hategan <hategan at mcs.anl.gov>:
> How many jobs did this run have?
> Did you observe a high cpu load on the head node while it was running?
> On Fri, 2009-06-19 at 13:42 -0500, Mihael Hategan wrote:
>> I'm looking for a complete trace (make sure you use cpu=times) in binary
>> format (format=b) that I can load and analyze in some profiler.
>> The think below says that waiting takes time. Which is not interesting
>> because at the same time waiting doesn't eat CPU.
>> On Fri, 2009-06-19 at 13:27 -0500, Allan Espinosa wrote:
>> > profile trace is in run02/java.hprof.txt
>> > summary:
>> > CPU SAMPLES BEGIN (total = 19493) Fri Jun 19 13:22:27 2009
>> > rank self accum count trace method
>> > 1 48.99% 48.99% 9550 300225 java.net.PlainSocketImpl.socketAccept
>> > 2 25.08% 74.07% 4888 300411 java.lang.UNIXProcess.waitForProcessExit
>> > 3 25.07% 99.14% 4887 300487
>> > org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run
>> > 4 0.18% 99.32% 36 300465 java.net.SocketInputStream.socketRead0
>> > 5 0.09% 99.42% 18 300472 java.net.SocketInputStream.socketRead0
>> > 6 0.05% 99.46% 9 300051 java.lang.ClassLoader.defineClass1
>> > 7 0.02% 99.48% 4 300498 java.lang.Shutdown.halt0
>> > 8 0.02% 99.50% 3 300101 java.lang.ClassLoader.findBootstrapClass
>> > 9 0.02% 99.51% 3 300123 java.util.zip.ZipFile.getEntry
>> > 10 0.02% 99.53% 3 300492 java.io.FileInputStream.available
>> > 11 0.01% 99.54% 2 300433 COM.claymoresystems.cert.CertContext.<clinit>
>> > 12 0.01% 99.55% 2 300435 java.io.FileInputStream.open
>> > 13 0.01% 99.56% 2 300447 java.lang.Throwable.fillInStackTrace
>> > 14 0.01% 99.57% 2 300460 java.util.zip.Inflater.inflateBytes
>> > 15 0.01% 99.58% 2 300491 java.lang.Throwable.fillInStackTrace
>> > CPU SAMPLES END
>> > -Allan
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090619/7fb45393/attachment.bin>
