[Swift-devel] coaster test failed on SDSC IA-64 Cluster
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Jun  2 18:13:59 CDT 2009
Do you mean a globus-job-run? or a test with a jobmanger other than coaster?
I did a globu-job-run, it was fine.
[zzhang at communicado coaster_new]$ globus-job-run
tg-login1.sdsc.teragrid.org /us
r/bin/id
uid=501593(zzhang) gid=5387(anl101) groups=5387(anl101)
zhao
Mihael Hategan wrote:
> Gram is failing, so you should try a plain gram job to confirm that it
> is indeed the issue.
> On Tue, 2009-06-02 at 15:42 -0500, Zhao Zhang wrote:
>> Hi, Mihael
>> The language behavior test failed on SDSC cluster. All gram and coaster
>> log files could be found at CI netowrk:
>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/sdsc/
>> I am attaching the stdout and the sites.xml definition of SDSC cluster
>> site. Could you help find out where things
>> go wrong? Thanks.
>> best
>> zhao
>> [zzhang at communicado sites]$ cat coaster_new/tgsdsc-pbs-gram2.xml
>> <config>
>>   <pool handle="tgsdsc" >
>>     <gridftp  url="gsiftp://tg-gridftp.sdsc.teragrid.org" />
>>     <execution  provider="coaster" url="tg-login1.sdsc.teragrid.org"
>> jobManager="gt2:gt2:pbs"/>
>>     <profile namespace="globus" key="project">TG-DBS080005N</profile>
>>     <workdirectory >/users/zzhang/work</workdirectory>
>>     <profile namespace="globus" key="slots">4</profile>
>>     <profile namespace="globus" key="nodeGranularity">2</profile>
>>     <profile namespace="globus" key="lowOverAllocation">5</profile>
>>     <profile namespace="globus" key="highOverAllocation">1</profile>
>>     <profile namespace="globus" key="maxNodes">2</profile>
>>     <profile namespace="globus" key="remoteMonitorEnabled">false</profile>
>>   </pool>
>> </config>
>> [zzhang at communicado sites]$ ./run-site coaster_new/tgsdsc-pbs-gram2.xml
>> testing site configuration: coaster_new/tgsdsc-pbs-gram2.xml
>> Removing files from previous runs
>> Running test 061-cattwo at Tue Jun 2 15:27:48 CDT 2009
>> Swift svn swift-r2949 cog-r2406
>> RunID: 20090602-1527-q2au81s2
>> Progress:
>> Progress:  Stage in:1
>> Progress:  Submitting:1
>> Progress:  Submitted:1
>> Progress:  Active:1
>> Progress: Failed but can retry:1
>> Failed to transfer wrapper log from
>> 061-cattwo-20090602-1527-q2au81s2/info/c on tgsdsc
>> Progress:  Active:1
>> 061-cattwo-20090602-1527-q2au81s2/info/e on tgsdsc
>> Progress:  Active:1
>> 061-cattwo-20090602-1527-q2au81s2/info/g on tgsdsc
>> Progress:  Failed:1
>> Execution failed:
>>         Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: tgsdsc
>> Directory: 061-cattwo-20090602-1527-q2au81s2/jobs/g/cat-gvrvuobj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>         Block task failed:
>> org.globus.gram.GramException: The job failed when the job manager
>> attempted to run it
>>         at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:531)
>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>         at java.lang.Thread.run(Thread.java:534)
>> Cleaning up...
>> Shutting down service at https://198.202.112.33:45214
>> Got channel MetaChannel: 25326891 -> GSSSChannel-null(1)
>> - Done
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
