[Swift-devel] coaster test failed on SDSC IA-64 Cluster
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jun  2 19:18:56 CDT 2009
Try doing a gobus-job-run to the PBS job manager, specifying your project.
Also try a simple swift job to the PBS job manager, with the same project.
- Mike
On 6/2/09 6:13 PM, Zhao Zhang wrote:
> Do you mean a globus-job-run? or a test with a jobmanger other than
> coaster?
> I did a globu-job-run, it was fine.
> [zzhang at communicado coaster_new]$ globus-job-run
> tg-login1.sdsc.teragrid.org /us
> r/bin/id
> uid=501593(zzhang) gid=5387(anl101) groups=5387(anl101)
> zhao
> Mihael Hategan wrote:
>> Gram is failing, so you should try a plain gram job to confirm that it
>> is indeed the issue.
>> On Tue, 2009-06-02 at 15:42 -0500, Zhao Zhang wrote:
>>> Hi, Mihael
>>> The language behavior test failed on SDSC cluster. All gram and
>>> coaster log files could be found at CI netowrk:
>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/sdsc/
>>> I am attaching the stdout and the sites.xml definition of SDSC
>>> cluster site. Could you help find out where things
>>> go wrong? Thanks.
>>> best
>>> zhao
>>> [zzhang at communicado sites]$ cat coaster_new/tgsdsc-pbs-gram2.xml
>>> <config>
>>>   <pool handle="tgsdsc" >
>>>     <gridftp  url="gsiftp://tg-gridftp.sdsc.teragrid.org" />
>>>     <execution  provider="coaster" url="tg-login1.sdsc.teragrid.org"
>>> jobManager="gt2:gt2:pbs"/>
>>>     <profile namespace="globus" key="project">TG-DBS080005N</profile>
>>>     <workdirectory >/users/zzhang/work</workdirectory>
>>>     <profile namespace="globus" key="slots">4</profile>
>>>     <profile namespace="globus" key="nodeGranularity">2</profile>
>>>     <profile namespace="globus" key="lowOverAllocation">5</profile>
>>>     <profile namespace="globus" key="highOverAllocation">1</profile>
>>>     <profile namespace="globus" key="maxNodes">2</profile>
>>> key="remoteMonitorEnabled">false</profile>
>>>   </pool>
>>> </config>
>>> [zzhang at communicado sites]$ ./run-site coaster_new/tgsdsc-pbs-gram2.xml
>>> testing site configuration: coaster_new/tgsdsc-pbs-gram2.xml
>>> Removing files from previous runs
>>> Running test 061-cattwo at Tue Jun 2 15:27:48 CDT 2009
>>> Swift svn swift-r2949 cog-r2406
>>> RunID: 20090602-1527-q2au81s2
>>> Progress:
>>> Progress:  Stage in:1
>>> Progress:  Submitting:1
>>> Progress:  Submitted:1
>>> Progress:  Active:1
>>> Progress: Failed but can retry:1
>>> Failed to transfer wrapper log from
>>> 061-cattwo-20090602-1527-q2au81s2/info/c on tgsdsc
>>> Progress:  Active:1
>>> 061-cattwo-20090602-1527-q2au81s2/info/e on tgsdsc
>>> Progress:  Active:1
>>> 061-cattwo-20090602-1527-q2au81s2/info/g on tgsdsc
>>> Progress:  Failed:1
>>> Execution failed:
>>>         Exception in cat:
>>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>>> Host: tgsdsc
>>> Directory: 061-cattwo-20090602-1527-q2au81s2/jobs/g/cat-gvrvuobj
>>> stderr.txt:
>>> stdout.txt:
>>> Caused by:
>>>         Block task failed:
>>> org.globus.gram.GramException: The job failed when the job manager
>>> attempted to run it
>>>         at
>>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:531)
>>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>>         at
>>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>>         at java.lang.Thread.run(Thread.java:534)
>>> Cleaning up...
>>> Shutting down service at https://198.202.112.33:45214
>>> Got channel MetaChannel: 25326891 -> GSSSChannel-null(1)
>>> - Done
>>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
