[Swift-devel] coaster test failed on SDSC IA-64 Cluster
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jun  2 17:19:02 CDT 2009
Gram is failing, so you should try a plain gram job to confirm that it
is indeed the issue.
On Tue, 2009-06-02 at 15:42 -0500, Zhao Zhang wrote:
> Hi, Mihael
> The language behavior test failed on SDSC cluster. All gram and coaster
> log files could be found at CI netowrk:
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/sdsc/
> I am attaching the stdout and the sites.xml definition of SDSC cluster
> site. Could you help find out where things
> go wrong? Thanks.
> best
> zhao
> [zzhang at communicado sites]$ cat coaster_new/tgsdsc-pbs-gram2.xml
> <config>
>   <pool handle="tgsdsc" >
>     <gridftp  url="gsiftp://tg-gridftp.sdsc.teragrid.org" />
>     <execution  provider="coaster" url="tg-login1.sdsc.teragrid.org"
> jobManager="gt2:gt2:pbs"/>
>     <profile namespace="globus" key="project">TG-DBS080005N</profile>
>     <workdirectory >/users/zzhang/work</workdirectory>
>     <profile namespace="globus" key="slots">4</profile>
>     <profile namespace="globus" key="nodeGranularity">2</profile>
>     <profile namespace="globus" key="lowOverAllocation">5</profile>
>     <profile namespace="globus" key="highOverAllocation">1</profile>
>     <profile namespace="globus" key="maxNodes">2</profile>
>     <profile namespace="globus" key="remoteMonitorEnabled">false</profile>
>   </pool>
> </config>
> [zzhang at communicado sites]$ ./run-site coaster_new/tgsdsc-pbs-gram2.xml
> testing site configuration: coaster_new/tgsdsc-pbs-gram2.xml
> Removing files from previous runs
> Running test 061-cattwo at Tue Jun 2 15:27:48 CDT 2009
> Swift svn swift-r2949 cog-r2406
> RunID: 20090602-1527-q2au81s2
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Progress: Failed but can retry:1
> Failed to transfer wrapper log from
> 061-cattwo-20090602-1527-q2au81s2/info/c on tgsdsc
> Progress:  Active:1
> 061-cattwo-20090602-1527-q2au81s2/info/e on tgsdsc
> Progress:  Active:1
> 061-cattwo-20090602-1527-q2au81s2/info/g on tgsdsc
> Progress:  Failed:1
> Execution failed:
>         Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: tgsdsc
> Directory: 061-cattwo-20090602-1527-q2au81s2/jobs/g/cat-gvrvuobj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Block task failed:
> org.globus.gram.GramException: The job failed when the job manager
> attempted to run it
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:531)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:534)
> Cleaning up...
> Shutting down service at https://198.202.112.33:45214
> Got channel MetaChannel: 25326891 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
