[Swift-devel] coaster test failed on SDSC IA-64 Cluster
Zhao Zhang
zhaozhang at uchicago.edu
Tue Jun 2 15:42:44 CDT 2009
Hi, Mihael
The language behavior test failed on SDSC cluster. All gram and coaster
log files could be found at CI netowrk:
/home/zzhang/swift_coaster/cog/modules/swift/tests/sites/sdsc/
I am attaching the stdout and the sites.xml definition of SDSC cluster
site. Could you help find out where things
go wrong? Thanks.
best
zhao
[zzhang at communicado sites]$ cat coaster_new/tgsdsc-pbs-gram2.xml
<config>
<pool handle="tgsdsc" >
<gridftp url="gsiftp://tg-gridftp.sdsc.teragrid.org" />
<execution provider="coaster" url="tg-login1.sdsc.teragrid.org"
jobManager="gt2:gt2:pbs"/>
<profile namespace="globus" key="project">TG-DBS080005N</profile>
<workdirectory >/users/zzhang/work</workdirectory>
<profile namespace="globus" key="slots">4</profile>
<profile namespace="globus" key="nodeGranularity">2</profile>
<profile namespace="globus" key="lowOverAllocation">5</profile>
<profile namespace="globus" key="highOverAllocation">1</profile>
<profile namespace="globus" key="maxNodes">2</profile>
<profile namespace="globus" key="remoteMonitorEnabled">false</profile>
</pool>
</config>
[zzhang at communicado sites]$ ./run-site coaster_new/tgsdsc-pbs-gram2.xml
testing site configuration: coaster_new/tgsdsc-pbs-gram2.xml
Removing files from previous runs
Running test 061-cattwo at Tue Jun 2 15:27:48 CDT 2009
Swift svn swift-r2949 cog-r2406
RunID: 20090602-1527-q2au81s2
Progress:
Progress: Stage in:1
Progress: Submitting:1
Progress: Submitted:1
Progress: Active:1
Progress: Failed but can retry:1
Failed to transfer wrapper log from
061-cattwo-20090602-1527-q2au81s2/info/c on tgsdsc
Progress: Active:1
061-cattwo-20090602-1527-q2au81s2/info/e on tgsdsc
Progress: Active:1
061-cattwo-20090602-1527-q2au81s2/info/g on tgsdsc
Progress: Failed:1
Execution failed:
Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: tgsdsc
Directory: 061-cattwo-20090602-1527-q2au81s2/jobs/g/cat-gvrvuobj
stderr.txt:
stdout.txt:
Caused by:
Block task failed:
org.globus.gram.GramException: The job failed when the job manager
attempted to run it
at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:531)
at org.globus.gram.GramJob.setStatus(GramJob.java:184)
at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
at java.lang.Thread.run(Thread.java:534)
Cleaning up...
Shutting down service at https://198.202.112.33:45214
Got channel MetaChannel: 25326891 -> GSSSChannel-null(1)
- Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
