[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
Michael Wilde wilde at mcs.anl.gov
Tue Jul 28 19:26:15 CDT 2009
Stu,
Glen Hocky has started testing a protein folding app called "OOPS" on
QueenBee under GRAM5. Initial tiny sanity tests look good; we'll move on
to running 100+ job runs, then larger.
We needed to figure out how to get Swift to use all 8 cores of the
QueenBee compute nodes, which we did.
Now we can start scaling up. Glen hopes to test more there shortly.
So far, no problems; no observed differences (in interface) with the new
GRAM.
Any chance of getting GRAM5 on the firefly host at UNL?
- Mike
On 7/28/09 11:17 AM, Stuart Martin wrote:
> On Jul 28, 2009, at Jul 28, 10:56 AM, Michael Wilde wrote:
>> Allan Espinosa will try to test AMPL workflows for the SEE project
>> there this week.
>> I may try a few others time permitting, but likely not this week.
>> Questions, Stu:
>> - do you want testing through Condor-G with the grid_monitor as well
>> as native?
> I'd say to use GRAM5 as is best for you/your users.  We've done some
> condor-g testing with and without the grid-monitor.  We did with, just
> for backward compatibility.  But without is recommended.  The
> grid-monitor is no longer needed with GRAM5.
> So, if you have users that use condor-g, then submit GRAM5 jobs with
> that.  But, turn off using the grid-monitor.
>     http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_7:_gram5-condor-g
> But if it is "better" to submit them natively, through cog API I
> assume(?), then do that.
>> - for native testing of GRAM5 (ie through the plain pre-WS GRAM
>> interface) are then any guidelines for how many jobs we can safely
>> submit at once, or should we not worry about limits? (ie sending a few
>> thousand jobs is OK?)
> Don't worry about it and submit away.  We need to know the
> limits/breaking points.
> But, to show what we've done in our testing, here are the results from
> our 5 client tests (each running in a separate VM) hitting the same
> GRAM5 service.
>     http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_4:_5-client-seg_2
>     http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_5:_5-client-seg-diffusers_2
> They submitted 5000 jobs over a 1 hour window to the same GRAM5
> service.  The load on the head node never went above 4 on the first and
> 7 on the second.
>> Allan: I just remembered that since Queenbee has 8-core hosts like
>> Abe, coasters is the only reasonable approach for large-scale testing.
>> But testing just a few AMPL jobs through plain GRAM5 seems a
>> reasonable step to do first.
>> I realize that coaster testing, also, wont give good CPU utilization
>> until the current "low demand" problem is solved.
>> - Mike
>> On 7/28/09 9:26 AM, Stuart Martin wrote:
>>> Hi Mike,
>>> Just following up on this.  Will there be some swift use of GRAM5 on
>>> queen bee this week?
>>> -Stu
>>> On Jul 21, 2009, at Jul 21, 5:23 PM, Michael Wilde wrote:
>>>> Yes, there are a few we can run on QueenBee.
>>>> Can try to test next week.
>>>> Allan, we can test SEE/AMPL, OOPS, and PTMap there.
>>>> - Mike
>>>> On 7/21/09 10:58 AM, Stuart Martin wrote:
>>>>> Are there any swift apps that can use queen bee?  There is a GRAM5
>>>>> service setup there for testing.
>>>>> -Stu
>>>>> Begin forwarded message:
>>>>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>>>>> Date: July 21, 2009 10:56:04 AM CDT
>>>>>> To: gateways at teragrid.org
>>>>>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski
>>>>>> <lukas at cct.lsu.edu>
>>>>>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>>>>>> Hi Gateways,
>>>>>> Any gateways that use (or can use) Queen Bee, it would be great if
>>>>>> you could target this new GRAM5 service that Lukasz deployed.  I
>>>>>> heard from Lukasz that Jim has submitted a gateway user (SAML) job
>>>>>> and that went through fine and populate the gram audit DB
>>>>>> correctly.  Thanks Jim!  It would be nice to have some gateway
>>>>>> push the service to test scalability.
>>>>>> Let us know if you plan to do this.
>>>>>> Thanks,
>>>>>> Stu
>>>>>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>>>>>> Date: July 21, 2009 1:18:05 AM CDT
>>>>>>> To: gram-user at lists.globus.org
>>>>>>> Subject: [gram-user] GRAM5 Alpha2
>>>>>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>>>>>> -seg-module pbs works fine.
>>>>>>> GRAM audit with PostgreSQL works fine.
>>>>>>> Can someone submit jobs as a gateway user? I'd like to check if
>>>>>>> the gateway_user field is written to our audit database.
>>>>>>> Thanks,
>>>>>>> Lukasz
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
