[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
    Stuart Martin
    smartin at mcs.anl.gov
    Wed Jul 29 10:25:54 CDT 2009
On Jul 28, 2009, at Jul 28, 7:26 PM, Michael Wilde wrote:
> Stu,
> Glen Hocky has started testing a protein folding app called "OOPS"
> on QueenBee under GRAM5. Initial tiny sanity tests look good; we'll
> move on to running 100+ job runs, then larger.
> We needed to figure out how to get Swift to use all 8 cores of the
> QueenBee compute nodes, which we did.
> Now we can start scaling up. Glen hopes to test more there shortly.
> So far, no problems; no observed differences (in interface) with the
> new GRAM.
Cool.  Let's see how things go as you ramp up.  I want to keep track
of GRAM5 application use cases and test results as I get them.
I took a stab at what I think is happening for this OOPS application.
I'm not sure if it is accurate, please take a look.
http://dev.globus.org/wiki/GRAM/GRAM5#Application_Testing
Then I'll need the details of one of the larger test runs that is done.
> Any chance of getting GRAM5 on the firefly host at UNL?
Yea, I (we) can ask.  But, maybe it makes sense to get some success
with using gram5 on queen bee first and then we ask Brian and say
look, we'd like/need gram5 installed there for testing?  Looks like
Firefly is running moab, so it would use the gram pbs adapter like
queen bee.
There is a CMS OSG effort going on now with Igor and Jeff Dost.  But
regardless, the more testing/deployments the better.
> - Mike
> On 7/28/09 11:17 AM, Stuart Martin wrote:
>> On Jul 28, 2009, at Jul 28, 10:56 AM, Michael Wilde wrote:
>>> Allan Espinosa will try to test AMPL workflows for the SEE project
>>> there this week.
>>> I may try a few others time permitting, but likely not this week.
>>> Questions, Stu:
>>> - do you want testing through Condor-G with the grid_monitor as
>>> well as native?
>> I'd say to use GRAM5 as is best for you/your users.  We've done
>> some condor-g testing with and without the grid-monitor.  We did
>> with, just for backward compatibility.  But without is
>> recommended.  The grid-monitor is no longer needed with GRAM5.
>> So, if you have users that use condor-g, then submit GRAM5 jobs
>> with that.  But, turn off using the grid-monitor.
>> GRAM5_Scalability_Results#Test_7:_gram5-condor-g But if it is
>> "better" to submit them natively, through cog API I assume(?), then
>> do that.
>>> - for native testing of GRAM5 (ie through the plain pre-WS GRAM
>>> interface) are then any guidelines for how many jobs we can safely
>>> submit at once, or should we not worry about limits? (ie sending a
>>> few thousand jobs is OK?)
>> Don't worry about it and submit away.  We need to know the limits/
>> breaking points.
>> But, to show what we've done in our testing, here are the results
>> from our 5 client tests (each running in a separate VM) hitting the
>> same GRAM5 service.
>>    http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_4:_5-
>> client-seg_2     http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_5
>> :_5-client-seg-diffusers_2 They submitted 5000 jobs over a 1 hour
>> window to the same GRAM5 service.  The load on the head node never
>> went above 4 on the first and 7 on the second.
>>> Allan: I just remembered that since Queenbee has 8-core hosts like
>>> Abe, coasters is the only reasonable approach for large-scale
>>> testing. But testing just a few AMPL jobs through plain GRAM5
>>> seems a reasonable step to do first.
>>> I realize that coaster testing, also, wont give good CPU
>>> utilization until the current "low demand" problem is solved.
>>> - Mike
>>> On 7/28/09 9:26 AM, Stuart Martin wrote:
>>>> Hi Mike,
>>>> Just following up on this.  Will there be some swift use of GRAM5
>>>> on queen bee this week?
>>>> -Stu
>>>> On Jul 21, 2009, at Jul 21, 5:23 PM, Michael Wilde wrote:
>>>>> Yes, there are a few we can run on QueenBee.
>>>>> Can try to test next week.
>>>>> Allan, we can test SEE/AMPL, OOPS, and PTMap there.
>>>>> - Mike
>>>>> On 7/21/09 10:58 AM, Stuart Martin wrote:
>>>>>> Are there any swift apps that can use queen bee?  There is a
>>>>>> GRAM5 service setup there for testing.
>>>>>> -Stu
>>>>>> Begin forwarded message:
>>>>>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>>>>>> Date: July 21, 2009 10:56:04 AM CDT
>>>>>>> To: gateways at teragrid.org
>>>>>>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski <lukas at cct.lsu.edu
>>>>>>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>>>>>>> Hi Gateways,
>>>>>>> Any gateways that use (or can use) Queen Bee, it would be
>>>>>>> great if you could target this new GRAM5 service that Lukasz
>>>>>>> deployed.  I heard from Lukasz that Jim has submitted a
>>>>>>> gateway user (SAML) job and that went through fine and
>>>>>>> populate the gram audit DB correctly.  Thanks Jim!  It would
>>>>>>> be nice to have some gateway push the service to test
>>>>>>> scalability.
>>>>>>> Let us know if you plan to do this.
>>>>>>> Thanks,
>>>>>>> Stu
>>>>>>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>>>>>>> Date: July 21, 2009 1:18:05 AM CDT
>>>>>>>> To: gram-user at lists.globus.org
>>>>>>>> Subject: [gram-user] GRAM5 Alpha2
>>>>>>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>>>>>>> -seg-module pbs works fine.
>>>>>>>> GRAM audit with PostgreSQL works fine.
>>>>>>>> Can someone submit jobs as a gateway user? I'd like to check
>>>>>>>> if the gateway_user field is written to our audit database.
>>>>>>>> Thanks,
>>>>>>>> Lukasz
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
