[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
Stuart Martin
smartin at mcs.anl.gov
Tue Jul 28 11:17:23 CDT 2009
On Jul 28, 2009, at Jul 28, 10:56 AM, Michael Wilde wrote:
> Allan Espinosa will try to test AMPL workflows for the SEE project
> there this week.
> I may try a few others time permitting, but likely not this week.
> Questions, Stu:
> - do you want testing through Condor-G with the grid_monitor as well
> as native?
I'd say to use GRAM5 as is best for you/your users. We've done some
condor-g testing with and without the grid-monitor. We did with, just
for backward compatibility. But without is recommended. The grid-
monitor is no longer needed with GRAM5.
So, if you have users that use condor-g, then submit GRAM5 jobs with
that. But, turn off using the grid-monitor.
http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_7:_gram5-
condor-g
But if it is "better" to submit them natively, through cog API I
assume(?), then do that.
> - for native testing of GRAM5 (ie through the plain pre-WS GRAM
> interface) are then any guidelines for how many jobs we can safely
> submit at once, or should we not worry about limits? (ie sending a
> few thousand jobs is OK?)
Don't worry about it and submit away. We need to know the limits/
breaking points.
But, to show what we've done in our testing, here are the results from
our 5 client tests (each running in a separate VM) hitting the same
GRAM5 service.
http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_4:_5-client-
seg_2
http://dev.globus.org/wiki/GRAM5_Scalability_Results#Test_5:_5-client-
seg-diffusers_2
They submitted 5000 jobs over a 1 hour window to the same GRAM5
service. The load on the head node never went above 4 on the first
and 7 on the second.
> Allan: I just remembered that since Queenbee has 8-core hosts like
> Abe, coasters is the only reasonable approach for large-scale
> testing. But testing just a few AMPL jobs through plain GRAM5 seems
> a reasonable step to do first.
> I realize that coaster testing, also, wont give good CPU utilization
> until the current "low demand" problem is solved.
> - Mike
> On 7/28/09 9:26 AM, Stuart Martin wrote:
>> Hi Mike,
>> Just following up on this. Will there be some swift use of GRAM5
>> on queen bee this week?
>> -Stu
>> On Jul 21, 2009, at Jul 21, 5:23 PM, Michael Wilde wrote:
>>> Yes, there are a few we can run on QueenBee.
>>> Can try to test next week.
>>> Allan, we can test SEE/AMPL, OOPS, and PTMap there.
>>> - Mike
>>> On 7/21/09 10:58 AM, Stuart Martin wrote:
>>>> Are there any swift apps that can use queen bee? There is a
>>>> GRAM5 service setup there for testing.
>>>> -Stu
>>>> Begin forwarded message:
>>>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>>>> Date: July 21, 2009 10:56:04 AM CDT
>>>>> To: gateways at teragrid.org
>>>>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski <lukas at cct.lsu.edu
>>>>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>>>>> Hi Gateways,
>>>>> Any gateways that use (or can use) Queen Bee, it would be great
>>>>> if you could target this new GRAM5 service that Lukasz
>>>>> deployed. I heard from Lukasz that Jim has submitted a gateway
>>>>> user (SAML) job and that went through fine and populate the gram
>>>>> audit DB correctly. Thanks Jim! It would be nice to have some
>>>>> gateway push the service to test scalability.
>>>>> Let us know if you plan to do this.
>>>>> Thanks,
>>>>> Stu
>>>>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>>>>> Date: July 21, 2009 1:18:05 AM CDT
>>>>>> To: gram-user at lists.globus.org
>>>>>> Subject: [gram-user] GRAM5 Alpha2
>>>>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>>>>> -seg-module pbs works fine.
>>>>>> GRAM audit with PostgreSQL works fine.
>>>>>> Can someone submit jobs as a gateway user? I'd like to check if
>>>>>> the gateway_user field is written to our audit database.
>>>>>> Thanks,
>>>>>> Lukasz
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
