[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jul 28 10:56:37 CDT 2009
Allan Espinosa will try to test AMPL workflows for the SEE project there
this week.
I may try a few others time permitting, but likely not this week.
Questions, Stu:
- do you want testing through Condor-G with the grid_monitor as well as
native?
- for native testing of GRAM5 (ie through the plain pre-WS GRAM
interface) are then any guidelines for how many jobs we can safely
submit at once, or should we not worry about limits? (ie sending a few
thousand jobs is OK?)
Allan: I just remembered that since Queenbee has 8-core hosts like Abe,
coasters is the only reasonable approach for large-scale testing. But
testing just a few AMPL jobs through plain GRAM5 seems a reasonable step
to do first.
I realize that coaster testing, also, wont give good CPU utilization
until the current "low demand" problem is solved.
- Mike
On 7/28/09 9:26 AM, Stuart Martin wrote:
> Hi Mike,
> Just following up on this.  Will there be some swift use of GRAM5 on
> queen bee this week?
> -Stu
> On Jul 21, 2009, at Jul 21, 5:23 PM, Michael Wilde wrote:
>> Yes, there are a few we can run on QueenBee.
>> Can try to test next week.
>> Allan, we can test SEE/AMPL, OOPS, and PTMap there.
>> - Mike
>> On 7/21/09 10:58 AM, Stuart Martin wrote:
>>> Are there any swift apps that can use queen bee?  There is a GRAM5
>>> service setup there for testing.
>>> -Stu
>>> Begin forwarded message:
>>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>>> Date: July 21, 2009 10:56:04 AM CDT
>>>> To: gateways at teragrid.org
>>>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski
>>>> <lukas at cct.lsu.edu>
>>>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>>>> Hi Gateways,
>>>> Any gateways that use (or can use) Queen Bee, it would be great if
>>>> you could target this new GRAM5 service that Lukasz deployed.  I
>>>> heard from Lukasz that Jim has submitted a gateway user (SAML) job
>>>> and that went through fine and populate the gram audit DB
>>>> correctly.  Thanks Jim!  It would be nice to have some gateway push
>>>> the service to test scalability.
>>>> Let us know if you plan to do this.
>>>> Thanks,
>>>> Stu
>>>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>>>> Date: July 21, 2009 1:18:05 AM CDT
>>>>> To: gram-user at lists.globus.org
>>>>> Subject: [gram-user] GRAM5 Alpha2
>>>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>>>> -seg-module pbs works fine.
>>>>> GRAM audit with PostgreSQL works fine.
>>>>> Can someone submit jobs as a gateway user? I'd like to check if the
>>>>> gateway_user field is written to our audit database.
>>>>> Thanks,
>>>>> Lukasz
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
