[Swift-devel] Fwd: [gram-user] GRAM5 Alpha2
    Stuart Martin
    smartin at mcs.anl.gov
    Tue Jul 28 09:26:30 CDT 2009
Hi Mike,
Just following up on this.  Will there be some swift use of GRAM5 on
queen bee this week?
-Stu
On Jul 21, 2009, at Jul 21, 5:23 PM, Michael Wilde wrote:
> Yes, there are a few we can run on QueenBee.
> Can try to test next week.
> Allan, we can test SEE/AMPL, OOPS, and PTMap there.
> - Mike
> On 7/21/09 10:58 AM, Stuart Martin wrote:
>> Are there any swift apps that can use queen bee?  There is a GRAM5
>> service setup there for testing.
>> -Stu
>> Begin forwarded message:
>>> From: Stuart Martin <smartin at mcs.anl.gov>
>>> Date: July 21, 2009 10:56:04 AM CDT
>>> To: gateways at teragrid.org
>>> Cc: Stuart Martin <smartin at mcs.anl.gov>, Lukasz Lacinski <lukas at cct.lsu.edu
>>> Subject: Fwd: [gram-user] GRAM5 Alpha2
>>> Hi Gateways,
>>> Any gateways that use (or can use) Queen Bee, it would be great if
>>> you could target this new GRAM5 service that Lukasz deployed.  I
>>> heard from Lukasz that Jim has submitted a gateway user (SAML) job
>>> and that went through fine and populate the gram audit DB
>>> correctly.  Thanks Jim!  It would be nice to have some gateway
>>> push the service to test scalability.
>>> Let us know if you plan to do this.
>>> Thanks,
>>> Stu
>>>> From: Lukasz Lacinski <lukas at cct.lsu.edu>
>>>> Date: July 21, 2009 1:18:05 AM CDT
>>>> To: gram-user at lists.globus.org
>>>> Subject: [gram-user] GRAM5 Alpha2
>>>> I've installed GRAM5 Alpha2 on Queen Bee.
>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-fork
>>>> queenbee.loni-lsu.teragrid.org:2120/jobmanager-pbs
>>>> -seg-module pbs works fine.
>>>> GRAM audit with PostgreSQL works fine.
>>>> Can someone submit jobs as a gateway user? I'd like to check if
>>>> the gateway_user field is written to our audit database.
>>>> Thanks,
>>>> Lukasz
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
