[Swift-devel] Problem using @extractint() on derived file
Michael Wilde
wilde at mcs.anl.gov
Tue Feb 24 16:29:19 CST 2009
Sorry, I think I see the problem. @extractint() wants a file-mapped
object (ie marker type), not a filename string. Now (I think) it seems
to work.
Is readData and readData2 the same?
On 2/24/09 3:33 PM, Mihael Hategan wrote:
> Sorry. Didn't look properly.
> Yes, this happens because @f can be resolved before f can be, so swift
> will happily do the extractint before echo finishes.
> I don't have a solution yet.
> On Tue, 2009-02-24 at 15:24 -0600, Michael Wilde wrote:
>> The file doesnt exist - its created in the script, and hence I would
>> expect it to be placed back in the dir that I ran swift from.
>> (But Ive been testing further, in my original scripts, and am seeing
>> confusing results, so I need to sort out and isolate.
>> I do this "y=f(x); rc=extractint(y)" pattern in a loop, thus I needed to
>> make the file name unique (else I get the "file already in cache"
>> error). So I switched to an anonymous file, and then started getting the
>> "no such file" error.
>> Whats confusing is I may have seen a csae similar to whats below that
>> did work, so I need to do more testing to isolate when it works and when
>> it fails.
>> Can you duplicate the failure with the simple script below?
>> - Mike
>> On 2/24/09 3:12 PM, Mihael Hategan wrote:
>>> Where is that file with respect to:
>>> - the script
>>> - the place you are running this from
>>> On Tue, 2009-02-24 at 15:07 -0600, Michael Wilde wrote:
>>>> This script:
>>>> type file;
>>>> app (file out) echo (string s) { echo s stdout=@out; }
>>>> file f<"a">;
>>>> int i;
>>>> f = echo("123");
>>>> i = @extractint(@f);
>>>> trace("i=", i);
>>>> produces:
>>>> Swift svn swift-r2552 cog-r2303
>>>> RunID: 20090224-1455-k1vj4uy7
>>>> Progress:
>>>> Execution failed:
>>>> Reading integer content of file
>>>> Caused by:
>>>> a (No such file or directory)
>>>> I seem to get the same behavior from readData, and the same if I
>>>> explicitly specify "a" as the argument to @extractint();
>>>> Is this because @extractint() is not waiting for "f" to get produced?
>>>> Ive extracted this example while debugging a script that uses an app to
>>>> test the termination condition of an iterate loop.
>>>> - Mike
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
