[Swift-devel] Problem using @extractint() on derived file
Ben Clifford
benc at hawaga.org.uk
Tue Feb 24 20:23:12 CST 2009
On Tue, 24 Feb 2009, Mihael Hategan wrote:
> Yes, this happens because @f can be resolved before f can be, so swift
> will happily do the extractint before echo finishes.
> I don't have a solution yet.
extractint probably should be able to take a file parameter, rather than a
string, and order evaluation properly.
which I think is what readData does (though its not in the test suite, I'm
told)
so it may be that replacing extractint(@f) with readData(f) (note the
lack of @) does what is desired
in which case, extractInt can be removed from the language.
