[Swift-devel] Problem using @extractint() on derived file
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 24 15:33:28 CST 2009
Sorry. Didn't look properly.
Yes, this happens because @f can be resolved before f can be, so swift
will happily do the extractint before echo finishes.
I don't have a solution yet.
On Tue, 2009-02-24 at 15:24 -0600, Michael Wilde wrote:
> The file doesnt exist - its created in the script, and hence I would
> expect it to be placed back in the dir that I ran swift from.
> (But Ive been testing further, in my original scripts, and am seeing
> confusing results, so I need to sort out and isolate.
> I do this "y=f(x); rc=extractint(y)" pattern in a loop, thus I needed to
> make the file name unique (else I get the "file already in cache"
> error). So I switched to an anonymous file, and then started getting the
> "no such file" error.
> Whats confusing is I may have seen a csae similar to whats below that
> did work, so I need to do more testing to isolate when it works and when
> it fails.
> Can you duplicate the failure with the simple script below?
> - Mike
> On 2/24/09 3:12 PM, Mihael Hategan wrote:
> > Where is that file with respect to:
> > - the script
> > - the place you are running this from
> > On Tue, 2009-02-24 at 15:07 -0600, Michael Wilde wrote:
> >> This script:
> >> type file;
> >> app (file out) echo (string s) { echo s stdout=@out; }
> >> file f<"a">;
> >> int i;
> >> f = echo("123");
> >> i = @extractint(@f);
> >> trace("i=", i);
> >> produces:
> >> Swift svn swift-r2552 cog-r2303
> >> RunID: 20090224-1455-k1vj4uy7
> >> Progress:
> >> Execution failed:
> >>          Reading integer content of file
> >> Caused by:
> >>          a (No such file or directory)
> >> I seem to get the same behavior from readData, and the same if I
> >> explicitly specify "a" as the argument to @extractint();
> >> Is this because @extractint() is not waiting for "f" to get produced?
> >> Ive extracted this example while debugging a script that uses an app to
> >> test the termination condition of an iterate loop.
> >> - Mike
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
