[Swift-devel] Problem using @extractint() on derived file
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Feb 24 15:24:21 CST 2009
The file doesnt exist - its created in the script, and hence I would
expect it to be placed back in the dir that I ran swift from.
(But Ive been testing further, in my original scripts, and am seeing
confusing results, so I need to sort out and isolate.
I do this "y=f(x); rc=extractint(y)" pattern in a loop, thus I needed to
make the file name unique (else I get the "file already in cache"
error). So I switched to an anonymous file, and then started getting the
"no such file" error.
Whats confusing is I may have seen a csae similar to whats below that
did work, so I need to do more testing to isolate when it works and when
it fails.
Can you duplicate the failure with the simple script below?
- Mike
On 2/24/09 3:12 PM, Mihael Hategan wrote:
> Where is that file with respect to:
> - the script
> - the place you are running this from
> On Tue, 2009-02-24 at 15:07 -0600, Michael Wilde wrote:
>> This script:
>> type file;
>> app (file out) echo (string s) { echo s stdout=@out; }
>> file f<"a">;
>> int i;
>> f = echo("123");
>> i = @extractint(@f);
>> trace("i=", i);
>> produces:
>> Swift svn swift-r2552 cog-r2303
>> RunID: 20090224-1455-k1vj4uy7
>> Progress:
>> Execution failed:
>>          Reading integer content of file
>> Caused by:
>>          a (No such file or directory)
>> I seem to get the same behavior from readData, and the same if I
>> explicitly specify "a" as the argument to @extractint();
>> Is this because @extractint() is not waiting for "f" to get produced?
>> Ive extracted this example while debugging a script that uses an app to
>> test the termination condition of an iterate loop.
>> - Mike
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
