[Swift-devel] filesystem mapper
    Ben Clifford
    benc at hawaga.org.uk
    Sat Feb 21 03:10:14 CST 2009
can you send me the .swift and .kml files for this?
Did you recompile your kml file after upgrading? If not, you may find a
kml file from an older Swift does not work with the present version.
On Fri, 20 Feb 2009, Zhao Zhang wrote:
> Hi,
> I have a problem with file system mapper in the latest version of swift.
> The code looks like:
> Mol texts[] <filesys_mapper;location="input/", suffix=".mol2">;
> It is trying to map all .mol2 files in the input directory, and it works fine
> with an older version of swift which is
> Swift svn swift-r2334 (Swift modified locally) cog-r2216
> But failed with the following information
> zzhang at login6.surveyor:~/new_dock6> ./run_swift_ssh.sh 1010 64 test.swift
> waiting for at least 64 nodes to register before submitting workload...
> waiting to find at least 1 services in file
> /home/falkon/users/zzhang/1010/config/Client-service-URIs.config...
> all done, file has found at least 1 services
> found at least 64 registered, submitting workload...
> Swift svn swift-r2578 cog-r2305
> RunID: 20090220-1428-ugfvnoya
> Progress:
> Execution failed:
>        Getting value for array texts.$[]/1 which is not permitted.
> The log file is at
> http://www.ci.uchicago.edu/~zzhang/test-20090220-1428-ugfvnoya.log
> zhao
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
