[Swift-devel] filesystem mapper
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri Feb 20 14:37:32 CST 2009
I have a problem with file system mapper in the latest version of swift.
The code looks like:
Mol texts[] <filesys_mapper;location="input/", suffix=".mol2">;
It is trying to map all .mol2 files in the input directory, and it works
fine with an older version of swift which is
Swift svn swift-r2334 (Swift modified locally) cog-r2216
But failed with the following information
zzhang at login6.surveyor:~/new_dock6> ./run_swift_ssh.sh 1010 64 test.swift
waiting for at least 64 nodes to register before submitting workload...
waiting to find at least 1 services in file
/home/falkon/users/zzhang/1010/config/Client-service-URIs.config...
all done, file has found at least 1 services
found at least 64 registered, submitting workload...
Swift svn swift-r2578 cog-r2305
RunID: 20090220-1428-ugfvnoya
Progress:
Execution failed:
        Getting value for array texts.$[]/1 which is not permitted.
The log file is at
http://www.ci.uchicago.edu/~zzhang/test-20090220-1428-ugfvnoya.log
zhao
