[Swift-devel] absolute path
    Ben Clifford
    benc at hawaga.org.uk
    Fri Feb 20 17:40:08 CST 2009
On Fri, 20 Feb 2009, Zhao Zhang wrote:
> it doesn't matter right now, I was just trying out the latest version of swift
> and stuck, then I solved the problem.
It does matter, in that I made a change that was, as far as I could see,
either identical or beneficial in all circumstances.
But apparently this change caused trouble for you.
If you write about what you were trying to do and how you solved your
problem, you will help the Swift developers understand what you are doing
and you are likely to encounter fewer problems in the future.
If you keep secrets, then we cannot help you.
