[Swift-devel] absolute path
Zhao Zhang zhaozhang at uchicago.edu
Fri Feb 20 17:32:15 CST 2009
it doesn't matter right now, I was just trying out the latest version of
swift and stuck, then I solved the problem.
zhao
Ben Clifford wrote:
> On Fri, 20 Feb 2009, Zhao Zhang wrote:
>> I found that in the latest swift code, the task description is using absolute
>> path like this:
>> /bin/bash /tmp/sleep-20090220-1646-7vdlcg0a/shared/wrapper.sh sleep-hoyn8x6j
>> -jobdir h/o -e /bin/sleep -out stdout.txt -err stderr.txt -i -d  -if  -of  -k
>> -a 30
>> I mean the "/tmp/sleep-20090220-1646-7vdlcg0a/shared/wrapper.sh" part.
>> Is there an option that we use relative path? thanks
> yes, that's a change made recently because I discovered that some sites do
> not respect the initial working directory specified in job submissions.
> In the rest of this thread, you don't clearly describe *why* you want a
> relative path - you're clearly trying to achieve some higher goal but it
> is not clear what.
