[Swift-devel] absolute path
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri Feb 20 17:20:03 CST 2009
I tried this
zzhang at login6.surveyor:/home/falkon/swift_scratch/cog/modules/swift> svn
update
U    src/org/griphyn/vdl/mapping/RootDataNode.java
Updated to revision 2579.
but there is no such texts in the swift.properties.
zhao
>>>> so, in the old version instead of
>>>> "/tmp/sleep-20090220-1646-7vdlcg0a/shared/wrapper.sh"
>>>> it is like this:
>>>> "shared/wrapper.sh"
>>>> by this I mean it is a relative path.
>>> Yes, of course, but relative paths are in respect to something. In
>>> other words, where do you want it to end on the remote site?
>> This is fine. I just made a change in the worker code, and it could
>> dynamically work with both cases.
>>>> I got another question about using signal notification instead of status
>>>> files,
>>>> as I remembered, there is an option in one property file for that,
>>> Have you tried swift.properties?
>> yes I tried, but I didn't find it.
> You should probably do an SVN update and look at the end of that file:
> # Controls how Swift will communicate the result code of running user programs
> # from workers to the submit side. In files mode, a file
> # indicating success or failure will be created on the site shared filesystem.
> # In provider mode, the execution provider job status will
> # be used. Notably, GRAM2 does not return job statuses correctly, and so
> # provider mode will not work with GRAM2. With other
> # providers, it can be used to reduce the amount of filesystem access compared
> # to files mode.
> # status.mode=files
