[Swift-devel] absolute path
Mihael Hategan
hategan at mcs.anl.gov
Fri Feb 20 17:29:35 CST 2009
----- Zhao Zhang <zhaozhang at uchicago.edu> wrote:
> I tried this
> zzhang at login6.surveyor:/home/falkon/swift_scratch/cog/modules/swift> svn
> update
> U src/org/griphyn/vdl/mapping/RootDataNode.java
> Updated to revision 2579.
> but there is no such texts in the swift.properties.
That's probably because you have a locally modified swift.properties
that got messed up.
Try this:
swift> cd etc
mv swift.properties swift.properties.mine
svn up
tail -n 16 swift.properties
Then manually merge your customization into swift.properties and
re-compile.
> zhao
> >>>> so, in the old version instead of
> >>>> "/tmp/sleep-20090220-1646-7vdlcg0a/shared/wrapper.sh"
> >>>> it is like this:
> >>>> "shared/wrapper.sh"
> >>>> by this I mean it is a relative path.
> >>> Yes, of course, but relative paths are in respect to something. In
> >>> other words, where do you want it to end on the remote site?
> >> This is fine. I just made a change in the worker code, and it could
> >> dynamically work with both cases.
> >>>> I got another question about using signal notification instead of status
> >>>> files,
> >>>> as I remembered, there is an option in one property file for that,
> >>> Have you tried swift.properties?
> >> yes I tried, but I didn't find it.
> > You should probably do an SVN update and look at the end of that file:
> > # Controls how Swift will communicate the result code of running user programs
> > # from workers to the submit side. In files mode, a file
> > # indicating success or failure will be created on the site shared filesystem.
> > # In provider mode, the execution provider job status will
> > # be used. Notably, GRAM2 does not return job statuses correctly, and so
> > # provider mode will not work with GRAM2. With other
> > # providers, it can be used to reduce the amount of filesystem access compared
> > # to files mode.
> > # status.mode=files
