[Swift-devel] GPFS issue of SWIFT on BGP
Ben Clifford benc at hawaga.org.uk
Tue Feb 10 14:20:33 CST 2009
On Tue, 10 Feb 2009, Zhao Zhang wrote:
> > > Here we got an old problem, all IO nodes are trying
> data transfer from  I/O nodes to submit-side client is  writing to GPFS
> through ssh-provider.
By 'old problem' I assumed you meant the GPFS locking problems previously
experienced, where GPFS locks for particular filesystem objects would
need to be expensively moved between nodes.
However, that should not be a problem here - from the GPFS perspective,
the submit (login) node is the only node that is interacting with GPFS,
and the only node that needs a lock on that directory.
If you're experiencing slowness, then I would be inclined to investigate
elsewhere. It may be that the ssh provider is not fast (ssh is not
renowned for being a fast protocol; Mihael might have some commentary
either way based on his experiences with the cog ssh provider); it may be
that something else is causing a bottleneck.
Do you have any detailed timing information? (from my perspective, the
wrapper logs for every job, and the submit side log, would be interesting
to look at - send those to me)
