[Swift-devel] GPFS issue of SWIFT on BGP
    Zhao Zhang
    zhaozhang at uchicago.edu
    Tue Feb 10 14:29:53 CST 2009
Hi
Ben Clifford wrote:
> On Tue, 10 Feb 2009, Zhao Zhang wrote:
>>>> Here we got an old problem, all IO nodes are trying
>> data transfer from  I/O nodes to submit-side client is  writing to GPFS
>> through ssh-provider.
> By 'old problem' I assumed you meant the GPFS locking problems previously
> experienced, where GPFS locks for particular filesystem objects would
> need to be expensively moved between nodes.
> However, that should not be a problem here - from the GPFS perspective,
> the submit (login) node is the only node that is interacting with GPFS,
> and the only node that needs a lock on that directory.
ok, this sounds reasonable. Thanks
> If you're experiencing slowness, then I would be inclined to investigate
> elsewhere. It may be that the ssh provider is not fast (ssh is not
> renowned for being a fast protocol; Mihael might have some commentary
> either way based on his experiences with the cog ssh provider); it may be
> that something else is causing a bottleneck.
> Do you have any detailed timing information? (from my perspective, the
> wrapper logs for every job, and the submit side log, would be interesting
> to look at - send those to me)
Nope, I am just making a work plan, those are potential issues, I will
send you the data once I got them.
zhao
