[Swift-devel] GPFS issue of SWIFT on BGP
Zhao Zhang
zhaozhang at uchicago.edu
Tue Feb 10 14:13:49 CST 2009
Ben Clifford wrote:
> On Tue, 10 Feb 2009, Zhao Zhang wrote:
>> Now, we start swift on Login Node, and the working directory will be created
>> on IO Node, so that all intermediate files and final
>> result files will be copied back to Login Node(GPFS) once they are generated.
>> Here we got an old problem, all IO nodes are trying
>> to write files in the same directory, which we are trying to avoid all the
>> way.
>> My solution would be modify the ssh-provider source code, implement an
>> asynchronous collector logic there.
> Can you describe what is going on here more explicitly.
> How do multiple IO nodes end up writing to the same GPFS directory?
In previous case, we have 512 IO nodes each create 1 file in the same
directory, that would take 30 minutes to finish.
Besides, some time only 510 files could be created.
> It is unclear to me from what you write how that comes about - as I
> understand it:
> . submit side data files are posix-accessed only by the swift submit-side
> client
yes
> . files on the I/O nodes (the remote sites) use pset-local storage
yes
> . any communication between the I/O nodes and submit-side client happens
> over ssh.
yes
> Where does an I/O node access machine-wide GPFS?
data transfer from I/O nodes to submit-side client is writing to GPFS
through ssh-provider.
zhao
