[Swift-devel] Problems with coasters and managedfork jobmanager
Mihael Hategan hategan at mcs.anl.gov
Mon Feb 9 14:34:04 CST 2009
I asked because I couldn't figure out how to get it to work.
But it seems like yours has problems, too:
mike at blabla tmp$ sh bootstrap.nonl.sh
bootstrap.nonl.sh: line 1: syntax error near unexpected token `;'
On Mon, 2009-02-09 at 14:23 -0600, Michael Wilde wrote:
> its www.ci.uchicago.edu/~wilde/bootstrap.nonl.sh, plus I removed the
> code in ServiceManager that inserted the extra newlines when reading it
> into a string buffer. I checked as far as verifying in the gram log that
> it was seen by gram as a single line in the rsl.  I never got a
> successful run from it, though - it ran into other problems later.
> On 2/9/09 1:46 PM, Mihael Hategan wrote:
> > On Fri, 2009-02-06 at 10:33 -0600, Michael Wilde wrote:
> >> I dont know, but I am testing a version where I removed the newlines
> >> from bootstrap.pl (and adjusted a few bits manually)
> > May we see that?
> >>  and I *think* its
> >> moving on to the next stage and trying to start the workers.
> >> Ben, it seems that *some* whitespace is passed on OK, in that I can run
> >> a job that does echo "hello world" and that blank after hello is
> >> preserved, and the job runs. I assume the whitespace problem is more
> >> subtle than that?
> >> On 2/6/09 10:24 AM, Mihael Hategan wrote:
> >>> On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
> >>>> On Fri, 6 Feb 2009, Mihael Hategan wrote:
> >>>>> I guess we'll have to stage in the bootstrap script using the stage-in
> >>>>> directive if we are to support managed fork, since I don't see OSG
> >>>>> fixing the issue.
> >>>> They are fixing the whitespace in parameters - see the gram-user thread I
> >>>> sent in a different message.
> >>> Does this include the new lines?
