[Swift-devel] Problems with coasters and managedfork jobmanager
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Feb  9 16:06:19 CST 2009
sorry, i think i put the wrong version there; i dealt with that specific
problem and hit a subtler one, deeper in the bootstrap process.
On 2/9/09 2:34 PM, Mihael Hategan wrote:
> I asked because I couldn't figure out how to get it to work.
> But it seems like yours has problems, too:
> mike at blabla tmp$ sh bootstrap.nonl.sh
> bootstrap.nonl.sh: line 1: syntax error near unexpected token `;'
> On Mon, 2009-02-09 at 14:23 -0600, Michael Wilde wrote:
>> its www.ci.uchicago.edu/~wilde/bootstrap.nonl.sh, plus I removed the
>> code in ServiceManager that inserted the extra newlines when reading it
>> into a string buffer. I checked as far as verifying in the gram log that
>> it was seen by gram as a single line in the rsl.  I never got a
>> successful run from it, though - it ran into other problems later.
>> On 2/9/09 1:46 PM, Mihael Hategan wrote:
>>> On Fri, 2009-02-06 at 10:33 -0600, Michael Wilde wrote:
>>>> I dont know, but I am testing a version where I removed the newlines
>>>> from bootstrap.pl (and adjusted a few bits manually)
>>> May we see that?
>>>>  and I *think* its
>>>> moving on to the next stage and trying to start the workers.
>>>> Ben, it seems that *some* whitespace is passed on OK, in that I can run
>>>> a job that does echo "hello world" and that blank after hello is
>>>> preserved, and the job runs. I assume the whitespace problem is more
>>>> subtle than that?
>>>> On 2/6/09 10:24 AM, Mihael Hategan wrote:
>>>>> On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
>>>>>> On Fri, 6 Feb 2009, Mihael Hategan wrote:
>>>>>>> I guess we'll have to stage in the bootstrap script using the stage-in
>>>>>>> directive if we are to support managed fork, since I don't see OSG
>>>>>>> fixing the issue.
>>>>>> They are fixing the whitespace in parameters - see the gram-user thread I
>>>>>> sent in a different message.
>>>>> Does this include the new lines?
