[Swift-devel] Problems with coasters and managedfork jobmanager
Michael Wilde wilde at mcs.anl.gov
Mon Feb 9 14:23:03 CST 2009
its www.ci.uchicago.edu/~wilde/bootstrap.nonl.sh, plus I removed the
code in ServiceManager that inserted the extra newlines when reading it
into a string buffer. I checked as far as verifying in the gram log that
it was seen by gram as a single line in the rsl.  I never got a
successful run from it, though - it ran into other problems later.
On 2/9/09 1:46 PM, Mihael Hategan wrote:
> On Fri, 2009-02-06 at 10:33 -0600, Michael Wilde wrote:
>> I dont know, but I am testing a version where I removed the newlines
>> from bootstrap.pl (and adjusted a few bits manually)
> May we see that?
>>  and I *think* its
>> moving on to the next stage and trying to start the workers.
>> Ben, it seems that *some* whitespace is passed on OK, in that I can run
>> a job that does echo "hello world" and that blank after hello is
>> preserved, and the job runs. I assume the whitespace problem is more
>> subtle than that?
>> On 2/6/09 10:24 AM, Mihael Hategan wrote:
>>> On Fri, 2009-02-06 at 16:17 +0000, Ben Clifford wrote:
>>>> On Fri, 6 Feb 2009, Mihael Hategan wrote:
>>>>> I guess we'll have to stage in the bootstrap script using the stage-in
>>>>> directive if we are to support managed fork, since I don't see OSG
>>>>> fixing the issue.
>>>> They are fixing the whitespace in parameters - see the gram-user thread I
>>>> sent in a different message.
>>> Does this include the new lines?
