[Swift-devel] Problems with coasters and managedfork jobmanager
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Feb  6 09:19:39 CST 2009
On 2/6/09 8:04 AM, Ben Clifford wrote:
> On Thu, 5 Feb 2009, Michael Wilde wrote:
>> I see Mats's note in a prio mail about concern that the managed-fork mechanism
>> may kill the coaster service, but no comments about script parsing errors.
> The condor jobmanager deals quite poorly with whitespace in arguments, in
> a way that I cannot see how to work around. (I've run into a very similar
> problem when looking at making Swift run without any shared filesystem).
> This bit almost definitely doesn't work with existing jobmanager-condor.
>>            js.setExecutable("/bin/bash");
>>            js.addArgument("-c");
>>            js.addArgument(loadBootstrapScript());
I see. The problem turns out to be the newlines in the command script.
It can be reproduced with globusrun:
com$ globusrun -o -r
tp-grid1.ci.uchicago.edu:2119/jobmanager-managedfork
'&(executable="/bin/echo") (arguments= "hello world")'
hello world
 >  world")'
ERROR: Failed to parse command file (line 10).
GRAM Job failed because the job failed when the job manager attempted to
run it (error code 17)
com$
I'll make a brief attempt to work around this, but most likely wont be
able to, as you say.
- Mike
> GRAM provided an update package to VDT/OSG the other day that changes
> condor jobmanager whitespace handling so that it may be possible to make
> it work. See this thread:
> http://lists.globus.org/pipermail/gram-user/2009-January/000790.html
> With the present deployed infrastructure, one approach might be to have
> the bootstrap script staged in as a file using file transfer mechanisms
> (in the quickest hack case, staged in at the same time as wrapper.sh and
> seq.sh by swift, though this will not work if you are trying to use the
> coaster filesystem provider), allowing the shell command to have spaces
> removed.
