[Swift-devel] Problems with coasters and managedfork jobmanager
Mihael Hategan hategan at mcs.anl.gov
Fri Feb 6 10:12:39 CST 2009
I guess we'll have to stage in the bootstrap script using the stage-in
directive if we are to support managed fork, since I don't see OSG
fixing the issue.
Unfortunately, this doesn't work very well with ws-gram.
On Fri, 2009-02-06 at 09:19 -0600, Michael Wilde wrote:
> On 2/6/09 8:04 AM, Ben Clifford wrote:
> > On Thu, 5 Feb 2009, Michael Wilde wrote:
> >> I see Mats's note in a prio mail about concern that the managed-fork mechanism
> >> may kill the coaster service, but no comments about script parsing errors.
> > The condor jobmanager deals quite poorly with whitespace in arguments, in
> > a way that I cannot see how to work around. (I've run into a very similar
> > problem when looking at making Swift run without any shared filesystem).
> > This bit almost definitely doesn't work with existing jobmanager-condor.
> >>            js.setExecutable("/bin/bash");
> >>            js.addArgument("-c");
> >>            js.addArgument(loadBootstrapScript());
> I see. The problem turns out to be the newlines in the command script.
> It can be reproduced with globusrun:
> com$ globusrun -o -r
> tp-grid1.ci.uchicago.edu:2119/jobmanager-managedfork
> '&(executable="/bin/echo") (arguments= "hello world")'
> hello world
>  >  world")'
> ERROR: Failed to parse command file (line 10).
> GRAM Job failed because the job failed when the job manager attempted to
> run it (error code 17)
> com$
> I'll make a brief attempt to work around this, but most likely wont be
> able to, as you say.
> - Mike
> > GRAM provided an update package to VDT/OSG the other day that changes
> > condor jobmanager whitespace handling so that it may be possible to make
> > it work. See this thread:
> > http://lists.globus.org/pipermail/gram-user/2009-January/000790.html
> > With the present deployed infrastructure, one approach might be to have
> > the bootstrap script staged in as a file using file transfer mechanisms
> > (in the quickest hack case, staged in at the same time as wrapper.sh and
> > seq.sh by swift, though this will not work if you are trying to use the
> > coaster filesystem provider), allowing the shell command to have spaces
> > removed.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
