[Swift-devel] coasters paths (was Re: Coasters failing on Teraport - cant find Java?)
Michael Wilde wilde at mcs.anl.gov
Thu Feb 5 16:26:52 CST 2009
Yeah, I agree. I just takes time and iterative testing.
I wonder if it would be useful to be able to run just bootstrap.sh in
some kind of test mode (ie give it args that just verify that it can
start a java service), and then run this from a script that does a
globus-job-run of the script to a growing set of sites.  And add that to
the build+test battery.
On 2/5/09 3:52 PM, Mihael Hategan wrote:
> ----- Allan Espinosa <aespinosa at cs.uchicago.edu> wrote:
>> I guess the best approach is create an environment agnostic http get
>> request.  From the standard Java network packages perhaps?
> Except you need a small script to download the jar file that
> implements that, finds java, and starts the downloader. Which
> is pretty much what the existing script does.
> So I think the solution is to fix the existing script.
