[Swift-devel] coasters paths (was Re: Coasters failing on Teraport - cant find Java?)
Mihael Hategan
hategan at mcs.anl.gov
Thu Feb 5 15:52:23 CST 2009
----- Allan Espinosa <aespinosa at cs.uchicago.edu> wrote:
> I guess the best approach is create an environment agnostic http get
> request. From the standard Java network packages perhaps?
Except you need a small script to download the jar file that
implements that, finds java, and starts the downloader. Which
is pretty much what the existing script does.
So I think the solution is to fix the existing script.
