[Swift-devel] coasters paths (was Re: Coasters failing on	Teraport - cant find Java?)
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Feb  5 17:07:48 CST 2009
----- Michael Wilde <wilde at mcs.anl.gov> wrote:
> Yeah, I agree. I just takes time and iterative testing.
Right.
> I wonder if it would be useful to be able to run just bootstrap.sh in
> some kind of test mode (ie give it args that just verify that it can
> start a java service), and then run this from a script that does a
> globus-job-run of the script to a growing set of sites.  And add that to
> the build+test battery.
It can be done. But I think it's one of those things where if you^1 can't
figure out how to do it^2, it's likely you won't contribute much to the
effort of fixing it.
1. "You" as in X.
2. Find the script, figure out the parameters, fake the environment, and
globusrun it.
