[Swift-devel] coasters paths (was Re: Coasters failing on Teraport - cant find Java?)
Allan Espinosa
aespinosa at cs.uchicago.edu
Thu Feb 5 14:18:39 CST 2009
Hi Mihael,
Tried out cog r2273 against swift r2486
The GRAM environment in Ranger has some stty permission errors. So
the coasters can't initialize the paths when it attempts to create a
"login" session
from the remote site:
/share/home/01035/tg802895/.globus/job/gatekeeper.ranger.tacc.teragrid.org
login4$ ls
login4$ ls
8851.1233864730
login4$ cd 8851.1233864730/
login4$ ls
stderr stdout x509_up
login4$ cat *
stty: standard input: Inappropriate ioctl for device
http://communicado.ci.uchicago.edu:50002: line 36: eval: --: invalid option
eval: usage: eval [arg ...]
Failed to download bootstrap jar from http://communicado.ci.uchicago.edu:50002
-----BEGIN CERTIFICATE-----
from submission site:
Progress: Failed:1
Execution failed:
Could not initialize shared directory on RANGER
Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException:
Failed to start coaster resource on
Caused by:
Could not start coaster service
Caused by:
Task ended before registration was received.
STDOUT: Failed to download bootstrap jar from
STDERR: null
I guess the best approach is create an environment agnostic http get
request. From the standard Java network packages perhaps?
-Allan
On Tue, Feb 3, 2009 at 7:59 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> cog r2272 contains a tentative fix for the issue. I tested it locally so
> far.
> On Tue, 2009-02-03 at 18:39 -0600, Allan Espinosa wrote:
>> I think i am using the latest revision (2271) for cog.
>> for swift my build is using 2490
>> On Tue, Feb 03, 2009 at 06:37:16PM -0600, Mihael Hategan wrote:
>> > What version of cog is this?
>> > It occurred to me that the change I made a few days ago might solve the
>> > java problem on some sites, but also mess up wget/curl lookup.
