[Swift-devel] Re: [Swift-user] gsiftp filesystem mapper removes leading slash
Ben Clifford
benc at hawaga.org.uk
Thu Feb 5 10:59:21 CST 2009
The fix in the below mentioned patch is in CoG r2273.
On Tue, 3 Feb 2009, Ben Clifford wrote:
> Moved from swift-user
> On Tue, 3 Feb 2009, Allan Espinosa wrote:
> > Oh i see. now I'm getting NullPointExceptions:
> > database pir[] <filesys_mapper;location="gsiftp://gridftp.ranger.tacc.teragrid.org//work/01035/tg802895/pir",
> > pattern="UNIPROT_for_blast_14.0.seq*">;
> I can recreate the same stacktrace you see, against my directory on
> teraport. The below change makes it go away for me.
> Get a clean fresh source tree, then:
> $ cd cog
> $ wget http://www.ci.uchicago.edu/~benc/tmp/ftpbug-1.patch
> $ patch -p1 < ftpbug-1.patch
> $ ant redist
> And try that.
> Probably you should keep a copy of your source tree before applying the
> patch so that you can easily get rid of it.
