[Swift-devel] Re: [Swift-user] gsiftp filesystem mapper removes leading slash
Allan Espinosa
aespinosa at cs.uchicago.edu
Thu Feb 5 12:53:28 CST 2009
Ok will try it out.
Thanks Ben!
-Allan
On Thu, Feb 5, 2009 at 10:59 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> The fix in the below mentioned patch is in CoG r2273.
> On Tue, 3 Feb 2009, Ben Clifford wrote:
>> Moved from swift-user
>> On Tue, 3 Feb 2009, Allan Espinosa wrote:
>> > Oh i see. now I'm getting NullPointExceptions:
>> > database pir[] <filesys_mapper;location="gsiftp://gridftp.ranger.tacc.teragrid.org//work/01035/tg802895/pir",
>> > pattern="UNIPROT_for_blast_14.0.seq*">;
>> I can recreate the same stacktrace you see, against my directory on
>> teraport. The below change makes it go away for me.
>> Get a clean fresh source tree, then:
>> $ cd cog
>> $ wget http://www.ci.uchicago.edu/~benc/tmp/ftpbug-1.patch
>> $ patch -p1 < ftpbug-1.patch
>> $ ant redist
>> And try that.
>> Probably you should keep a copy of your source tree before applying the
>> patch so that you can easily get rid of it.
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
