[Swift-devel] RE: [Swift-user] Execution error
Yue, Chen - BMD yuechen at bsd.uchicago.edu
Thu Apr 30 18:12:19 CDT 2009
Hi Mihael,
I tried and the error message is the same. I attached the following trace.
[yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file sites.xml -tc.file tc.data
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090430-1809-ppue84jc
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1809-ppue84jc/info/m on TACC_LoneStar
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1809-ppue84jc/info/o on TACC_LoneStar
Progress:  Active:1
Failed to transfer wrapper log from PTMap2-unmod-20090430-1809-ppue84jc/info/q on TACC_LoneStar
Progress:  Failed:1
Execution failed:
        Exception in PTMap2:
Arguments: [e04.mzXML, ./seqs-ecolik12/fasta02, inputs-unmod.txt, parameters.txt]
Host: TACC_LoneStar
Directory: PTMap2-unmod-20090430-1809-ppue84jc/jobs/q/PTMap2-q3acr5aj
stderr.txt:
stdout.txt:
Caused by:
        Cannot submit job
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot submit job
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:145)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:99)
        at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
        at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:43)
        at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.startWorker(WorkerManager.java:221)
        at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.run(WorkerManager.java:145)
Caused by: org.globus.gram.GramException: The gatekeeper failed to find the requested service
        at org.globus.gram.Gram.checkHttpReply(Gram.java:137)
        at org.globus.gram.Gram.request(Gram.java:342)
        at org.globus.gram.GramJob.request(GramJob.java:262)
        at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:133)
        ... 5 more
Cleaning up...
Shutting down service at https://129.114.50.32:35904 <https://129.114.50.32:35904>
Got channel MetaChannel: 16618296 -> GSSSChannel-null(1)
- Done
My sites.xml for TACC Lonestar is :
 <pool handle="TACC_LoneStar">
    <gridftp url="gsiftp://tg-gridftp.lonestar.tacc.teragrid.org"/>
    <execution provider="coaster" url="gatekeeper.lonestar.tacc.teragrid.org" jobManager="gt2:gt2:pbs"/>
    <workdirectory>/tmp/scratch/yc/swiftwork</workdirectory>
 </pool>
Thanks!
Chen, Yue
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Thu 4/30/2009 6:08 PM
To: Yue, Chen - BMD
Cc: Michael Wilde; swift-devel
Subject: RE: [Swift-devel] RE: [Swift-user] Execution error
Odd. Try "gt2:gt2:pbs" instead of "gt2:gt2:PBS".
On Thu, 2009-04-30 at 17:57 -0500, Yue, Chen - BMD wrote:
> Hi Mihael,
> The error message is different after I change from gt2:PBS to
> gt2:gt2:PBS on TACC LoneStar. I attached the trace as following. I
> don't know if there is still setup problem. Thank you very much!
> RunID: 20090430-1742-tfabq6q4
> Progress:
> Progress:  Active:1
> PTMap2-unmod-20090430-1742-tfabq6q4/info/r on TACC_LoneStar
> Progress:  Active:1
> PTMap2-unmod-20090430-1742-tfabq6q4/info/t on TACC_LoneStar
> Progress:  Active:1
> PTMap2-unmod-20090430-1742-tfabq6q4/info/v on TACC_LoneStar
> Progress:  Failed:1
> Execution failed:
> parameters.txt]
> Host: TACC_LoneStar
> Directory: PTMap2-unmod-20090430-1742-tfabq6q4/jobs/v/PTMap2-v7baq5aj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Cannot submit job
> Cannot submit job
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         ... 5 more
> Cleaning up...
> Shutting down service at https://129.114.50.32:35257 <https://129.114.50.32:35257/>
> Got channel MetaChannel: 13391897 -> GSSSChannel-null(1)
> - Done
> Chen, Yue
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090430/eb05c436/attachment.html>
