[Swift-devel] RE: [Swift-user] Execution error
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr 30 17:36:32 CDT 2009
On Thu, 2009-04-30 at 17:23 -0500, Michael Wilde wrote:
> On 4/30/09 5:13 PM, Mihael Hategan wrote:
>  >> GRAM Job submission failed because the job manager failed to open
> stderr
>  >> (error code 74)
>  > That seems like an IP address problem. Make sure you set GLOBUS_HOSTNAME
>  > properly.
> OK, I will try that. But in the test below, I caused the error by
> unsetting X509_CERT_DIR and fixed the error by resetting it - no other
> changes.
> I *think* that as recently as a few weeks ago globus-job-run to ranger
> worked with just @globus in my .soft file.
> Adding +osg-client seemed to make it work by setting X509_CERT_DIR.
> So as far as I can tell, at least at the level of globus-job-run, these
> seems to be related to certs.
> Given what Im seeing, do you still think GLOBUS_HOSTNAME is a factor?
I find it hard to tell what the osg client is doing or not doing. The
gold standard is the plain globus gram client. Besides that, the cog
globusrun is the next step (because that's what swift uses).
