[Swift-devel] RE: [Swift-user] Execution error
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Apr 30 16:52:43 CDT 2009
Hi, Glen
Can you point me to the working swift on ranger?
zhao
Glen Hocky wrote:
> I have the identical response on ranger. It started yesterday evening.
> Possibly a problem that the TACC folks need to fix?
> Glen
> Yue, Chen - BMD wrote:
>> Hi Michael,
>> Thank you for the advices. I tested ranger with 1 job and new
>> specifications of maxwalltime. It shows the following error message.
>> I don't know if there is other problem with my setup. Thank you!
>> [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file
>> sites.xml -tc.file tc.data
>> Swift 0.9rc2 swift-r2860 cog-r2388
>> RunID: 20090430-1559-2vi6x811
>> Progress:
>> Progress:  Stage in:1
>> Progress:  Submitting:1
>> Progress:  Submitted:1
>> Progress:  Active:1
>> Failed to transfer wrapper log from
>> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
>> Progress:  Active:1
>> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
>> Progress:  Active:1
>> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
>> Progress:  Failed:1
>> Execution failed:
>>         Exception in PTMap2:
>> Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
>> parameters.txt]
>> Host: ranger
>> Directory: PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>         Failed to start worker:
>> null
>> null
>> org.globus.gram.GramException: The job manager detected an invalid
>> script response
>>         at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>         at
>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>         at java.lang.Thread.run(Thread.java:619)
>> Cleaning up...
>> Shutting down service at https://129.114.50.163:45562
>> <https://129.114.50.163:45562>
>> Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
>> - Done
>> Chen, Yue
>> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
>> *Sent:* Thu 4/30/2009 3:02 PM
>> *To:* Yue, Chen - BMD; swift-devel
>> *Subject:* Re: [Swift-user] Execution error
>> Back on list here (I only went off-list to discuss accounts, etc)
>> The problem in the run below is this:
>> 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
>> jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
>> the given max walltime worker constraint (task: 3000, \
>> maxwalltime: 2400s)
>> You have this on the ptmap app in your tc.data:
>> globus::maxwalltime=50
>> But you only gave coasters 40 mins per coaster worker. So its
>> complaining that it cant run a 50 minute job in a 40 minute (max)
>> coaster worker. ;)
>> I mentioned in a prior mail that you need to set the two time vals in
>> your sites.xml entry; thats what you need to do next, now.
>> change the coaster time in your sites.xml to:
>>      key="coasterWorkerMaxwalltime">00:51:00</profile>
>> If you have more info on the variability of your ptmap run times, send
>> that to the list, and we can discuss how to handle.
>> (NOTE: doing grp -i of the log for "except" or scanning for "except"
>> with an editor will often locate the first "exception" that your job
>> encountered. Thats how I found the error above).
>> Also, Yue, for testing new sites, or for validating that old sites still
>> work, you should create the smallest possible ptmap workflow - 1 job if
>> that is possible - and verify that this works.  Then say 10 jobs to make
>> sure scheduling etc is sane.  Then, send in your huge jobs.
>> With only 1 job, its easier to spot the errors in the log file.
>> - Mike
>> On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
>> > Hi Michael,
>> > > I run into the same messages again when I use Ranger:
>> > > Progress:  Selecting site:146  Stage in:25  Submitting:15
>> Submitted:821
>> > Failed but can retry:16
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
>> > Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
>> > PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
>> > The log for the search is at : >
>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
>> > > The sites.xml I have is:
>> > >  <pool handle="ranger">
>> >      <execution provider="coaster"
>> >                 url="gatekeeper.ranger.tacc.teragrid.org"
>> >                 jobManager="gt2:gt2:SGE"/>
>> >      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
>> >      <profile namespace="env"
>> >               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
>> >      <profile namespace="globus" key="project">TG-CCR080022N</profile>
>> >      <profile namespace="globus" key="coastersPerNode">16</profile>
>> >      <profile namespace="globus" key="queue">development</profile>
>> >               key="coasterWorkerMaxwalltime">00:40:00</profile>
>> >      <profile namespace="globus" key="maxwalltime">31</profile>
>> >      <profile namespace="karajan" key="initialScore">50</profile>
>> >      <profile namespace="karajan" key="jobThrottle">10</profile>
>> >      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
>> >  </pool>
>> > The tc.data I have is:
>> > > ranger          PTMap2         >
>> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED      >
>> INTEL32::LINUX  globus::maxwalltime=50
>> > I'm using swift 0.9 rc2
>> > Thank you very much for help!
>> > Chen, Yue
>> > *Sent:* Thu 4/30/2009 2:05 PM
>> > On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
>> >  > Hi Michael,
>> >  > When I tried to activate my account, I encountered the following
>> error:
>> >  > "Sorry, this account is in an invalid state. You may not
>> activate your
>> >  > at this time."
>> >  > I used the username and password from TG-CDA070002T. Should I use a
>> >  > different password?
>> > If you can already login to Ranger, then you are all set - you must
>> have
>> > done this previously.
>> > I thought you had *not*, because when I looked up your login on ranger
>> > ("finger yuechen") it said "never logged in". But seems like that info
>> > is incorrect.
>> > If you have ptmap compiled, seems like you are almost all set.
>> > Let me know if it works.
>> > - Mike
>> >  > Thanks!
>> >  > Chen, Yue
>> >  > *Sent:* Thu 4/30/2009 1:07 PM
>> >  > *Cc:* swift user
>> >  > Yue, use this XML pool element to access ranger:
>> >  >      <gridftp
>> >  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
>> >  >    </pool>
>> >  > You will need to also do these steps:
>> >  > Go to this web page to enable your Ranger account:
>> >  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
>> >  > Then login to Ranger via the TeraGrid portal and put your ssh
>> keys in
>> >  > place (assuming you use ssh keys, which you should)
>> >  > While on Ranger, do this:
>> >  > echo $WORK
>> >  > mkdir $work/swiftwork
>> >  > and put the full path of your $WORK/swiftwork directory in the
>> >  > <workdirectory> element above. (My login is tg455etc, yours is
>> yuechen)
>> >  > Then scp your code to Ranger and compile it.
>> >  > Then create a tc.data entry for your ptmap app
>> >  > Next, set your time values in the sites.xml entry above to suitable
>> >  > values for Ranger. You'll need to measure times, but I think you
>> will
>> >  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
>> >  > The values above were set for one app job per coaster. I think
>> you can
>> >  > probably do more.
>> >  > If you estimate a run time of 5 minutes, use:
>> >  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
>> >  >      <profile namespace="globus" key="maxwalltime">5</profile>
>> >  > Other people on the list - please sanity check what I suggest here.
>> >  > - Mike
>> >  > On 4/30/09 12:40 PM, Michael Wilde wrote:
>> >  >  > I just checked - TG-CDA070002T has indeed expired.
>> >  >  > The best for now is to move to use (only) Ranger, under this
>> account:
>> >  >  > TG-CCR080022N
>> >  >  > I will locate and send you a sites.xml entry in a moment.
>> >  >  > You need to go to a web page to activate your Ranger login.
>> >  >  > Best to contact me in IM and we can work this out.
>> >  >  > - Mike
>> >  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
>> >  >  >> Also, what account are you running under? We may need to change
>> > you to
>> >  >  >> a new account - as the OSG Training account expires today.
>> >  >  >> If that happend at Noon, it *might* be the problem.
>> >  >  >> - Mike
>> >  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
>> >  >  >>> Hi,
>> >  >  >>> I came back to re-run my application on NCSA Mercury which was
>> > tested
>> >  >  >>> successfully last week after I just set up coasters with
>> swift 0.9,
>> >  >  >>> but I got many messages like the following:
>> >  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
>> >  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
>> > but can
>> >  >  >>> retry:1
>> >  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556
>> Failed but can
>> >  >  >>> retry:4
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
>> >  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
>> >  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
>> > retry:8
>> >  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
>> >  >  >>> The log file for the successful run last week is ;
>> >  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
>> >  >  >>> The log file for the failed run is :
>> >  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
>> >  >  >>> I don't think I did anything different, so I don't know why
>> this
>> > time
>> >  >  >>> they failed. The sites.xml for Mercury is:
>> >  >  >>>  <pool handle="NCSA_MERCURY">
>> >  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
>> url="grid-hg.ncsa.teragrid.org"
>> >  >  >>> jobManager="gt2:PBS"/>
>> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
>> >  >  >>>     <profile namespace="globus" key="queue">debug</profile>
>> >  >  >>>  </pool>
>> >  >  >>> Thank you for help!
>> >  >  >>> Chen, Yue
>> >  >  >>> This email is intended only for the use of the individual
>> or entity
>> >  >  >>> to which it is addressed and may contain information that is
>> >  >  >>> privileged and confidential. If the reader of this email
>> message is
>> >  >  >>> not the intended recipient, you are hereby notified that any
>> >  >  >>> dissemination, distribution, or copying of this
>> communication is
>> >  >  >>> prohibited. If you have received this email in error,
>> please notify
>> >  >  >>> the sender and destroy/delete all copies of the transmittal.
>> > Thank you.
>> >  >  >>> _______________________________________________
>> >  >  >>> Swift-user mailing list
>> >  >  >>> Swift-user at ci.uchicago.edu
>> >  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>> >  > This email is intended only for the use of the individual or
>> entity to
>> privileged and
>> >  > confidential. If the reader of this email message is not the
>> intended
>> >  > recipient, you are hereby notified that any dissemination,
>> distribution,
>> >  > or copying of this communication is prohibited. If you have
>> received
>> >  > this email in error, please notify the sender and destroy/delete
>> all
>> >  > copies of the transmittal. Thank you.
>> > This email is intended only for the use of the individual or entity to
>> privileged and
>> > confidential. If the reader of this email message is not the intended
>> distribution,
>> > or copying of this communication is prohibited. If you have received
>> > this email in error, please notify the sender and destroy/delete all
>> privileged and confidential. If the reader of this email message is
>> dissemination, distribution, or copying of this communication is
>> prohibited. If you have received this email in error, please notify
>> the sender and destroy/delete all copies of the transmittal. Thank you.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
