[Swift-devel] RE: [Swift-user] Execution error
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr 30 17:13:19 CDT 2009
On Thu, 2009-04-30 at 17:01 -0500, Michael Wilde wrote:
> A bit more info on this: it *seems* like a cert issue.
> I last accessed Ranger via globus-job-run perhaps 2 weeks ago, no problem.
> Yesterday, while debugging with Glen, globus-job-run was giving me GRAM
> err 74. (and GRM err 12 to all other sites)
> So I added +osg-client to my .soft file, and then globus-job-run worked.
> But I noticed that my globus-job-run was still coming from the GT4 dir,
> not from an OSG dir.
> Just now I traced this back to X509_CERT_DIR:
> <works here>  then I did:
> com$ unset X509_CERT_DIR
> com$ globus-job-run gatekeeper.ranger.tacc.teragrid.org /usr/bin/id
> GRAM Job submission failed because the job manager failed to open stderr
> (error code 74)
That seems like an IP address problem. Make sure you set GLOBUS_HOSTNAME
properly.
> com$
> com$
> com$ X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
> (error code 74)
> com$ export X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
> uid=455797(tg455797) gid=80243(G-80243)
> groups=80243(G-80243),81031(G-81031),81411(G-81411),81611(G-81611),81613(G-81613),81621(G-81621),81747(G-81747),81792(G-81792),800744(G-800744),800745(G-800745),800889(G-800889),800981(G-800981),800983(G-800983),801271(G-801271),801364(G-801364)
> com$
> Mihael, does swift honor X509_CERT_DIR? If so, Glen, Yue, that is
> something to try.
> You may need to put +osg-client this in your .soft file and re-login:
> @python-2.5
> +java-sun
> +apache-ant
> +gx-map
> +condor
> +gx-map
> @globus-4
> @default
> +R
> +torque
> +maui
> +matlab-7.7
> +osg-client
> - Mike
> On 4/30/09 4:39 PM, Michael Wilde wrote:
> > And we should also drill back down to why (at least yesterday) the GT4
> > softev package failed, but the OSG client worked, for globus-job-run.
> > I guess its possible there is a host or CA cert issue here.
> > - Mike
> > On 4/30/09 4:31 PM, Mihael Hategan wrote:
> >> Can you guys try to run first.swift on ranger with the settings you have
> >> (you'll need to add "echo" to tc.data)?
> >> On Thu, 2009-04-30 at 16:13 -0500, Glen Hocky wrote:
> >>> I have the identical response on ranger. It started yesterday
> >>> evening. Possibly a problem that the TACC folks need to fix?
> >>> Glen
> >>> Yue, Chen - BMD wrote:
> >>>> Hi Michael,
> >>>> Thank you for the advices. I tested ranger with 1 job and new
> >>>> specifications of maxwalltime. It shows the following error message.
> >>>> I don't know if there is other problem with my setup. Thank you!
> >>>> [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file
> >>>> sites.xml -tc.file tc.data
> >>>> Swift 0.9rc2 swift-r2860 cog-r2388
> >>>> RunID: 20090430-1559-2vi6x811
> >>>> Progress:
> >>>> Progress:  Stage in:1
> >>>> Progress:  Submitting:1
> >>>> Progress:  Submitted:1
> >>>> Progress:  Active:1
> >>>> Failed to transfer wrapper log from
> >>>> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
> >>>> Progress:  Active:1
> >>>> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
> >>>> Progress:  Active:1
> >>>> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
> >>>> Progress:  Failed:1
> >>>> Execution failed:
> >>>>         Exception in PTMap2:
> >>>> Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
> >>>> parameters.txt]
> >>>> Host: ranger
> >>>> Directory: PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
> >>>> stderr.txt:
> >>>> stdout.txt:
> >>>> Caused by:
> >>>>         Failed to start worker:
> >>>> null
> >>>> null
> >>>> org.globus.gram.GramException: The job manager detected an invalid
> >>>> script response
> >>>>         at
> >>>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
> >>>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
> >>>>         at
> >>>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
> >>>>         at java.lang.Thread.run(Thread.java:619)
> >>>> Cleaning up...
> >>>> Shutting down service at https://129.114.50.163:45562
> >>>> <https://129.114.50.163:45562>
> >>>> Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
> >>>> - Done
> >>>> Chen, Yue
> >>>> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
> >>>> *Sent:* Thu 4/30/2009 3:02 PM
> >>>> *To:* Yue, Chen - BMD; swift-devel
> >>>> *Subject:* Re: [Swift-user] Execution error
> >>>> Back on list here (I only went off-list to discuss accounts, etc)
> >>>> The problem in the run below is this:
> >>>> 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
> >>>> jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
> >>>> the given max walltime worker constraint (task: 3000, \
> >>>> maxwalltime: 2400s)
> >>>> You have this on the ptmap app in your tc.data:
> >>>> globus::maxwalltime=50
> >>>> But you only gave coasters 40 mins per coaster worker. So its
> >>>> complaining that it cant run a 50 minute job in a 40 minute (max)
> >>>> coaster worker. ;)
> >>>> I mentioned in a prior mail that you need to set the two time vals in
> >>>> your sites.xml entry; thats what you need to do next, now.
> >>>> change the coaster time in your sites.xml to:
> >>>>      key="coasterWorkerMaxwalltime">00:51:00</profile>
> >>>> If you have more info on the variability of your ptmap run times, send
> >>>> that to the list, and we can discuss how to handle.
> >>>> (NOTE: doing grp -i of the log for "except" or scanning for "except"
> >>>> with an editor will often locate the first "exception" that your job
> >>>> encountered. Thats how I found the error above).
> >>>> Also, Yue, for testing new sites, or for validating that old sites
> >>>> still
> >>>> work, you should create the smallest possible ptmap workflow - 1 job if
> >>>> that is possible - and verify that this works.  Then say 10 jobs to
> >>>> make
> >>>> sure scheduling etc is sane.  Then, send in your huge jobs.
> >>>> With only 1 job, its easier to spot the errors in the log file.
> >>>> - Mike
> >>>> On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
> >>>>> Hi Michael,
> >>>>> I run into the same messages again when I use Ranger:
> >>>>> Progress:  Selecting site:146  Stage in:25  Submitting:15
> >>>>> Submitted:821
> >>>>> Failed but can retry:16
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
> >>>>> Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
> >>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
> >>>>> The log for the search is at :
> >>>>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
> >>>>> The sites.xml I have is:
> >>>>>  <pool handle="ranger">
> >>>>>      <execution provider="coaster"
> >>>>>                 url="gatekeeper.ranger.tacc.teragrid.org"
> >>>>>                 jobManager="gt2:gt2:SGE"/>
> >>>>>      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
> >>>>>      <profile namespace="env"
> >>>>>               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
> >>>>>      <profile namespace="globus" key="project">TG-CCR080022N</profile>
> >>>>>      <profile namespace="globus" key="coastersPerNode">16</profile>
> >>>>>      <profile namespace="globus" key="queue">development</profile>
> >>>>>               key="coasterWorkerMaxwalltime">00:40:00</profile>
> >>>>>      <profile namespace="globus" key="maxwalltime">31</profile>
> >>>>>      <profile namespace="karajan" key="initialScore">50</profile>
> >>>>>      <profile namespace="karajan" key="jobThrottle">10</profile>
> >>>>>      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
> >>>>>  </pool>
> >>>>> The tc.data I have is:
> >>>>> ranger          PTMap2
> >>>>> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED
> >>>>> INTEL32::LINUX  globus::maxwalltime=50
> >>>>> I'm using swift 0.9 rc2
> >>>>> Thank you very much for help!
> >>>>> Chen, Yue
> >>>>> *Sent:* Thu 4/30/2009 2:05 PM
> >>>>> On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
> >>>>>  > Hi Michael,
> >>>>>  > When I tried to activate my account, I encountered the following
> >>>> error:
> >>>>>  > "Sorry, this account is in an invalid state. You may not activate
> >>>> your
> >>>>>  > at this time."
> >>>>>  > I used the username and password from TG-CDA070002T. Should I use a
> >>>>>  > different password?
> >>>>> If you can already login to Ranger, then you are all set - you must
> >>>>> have
> >>>>> done this previously.
> >>>>> I thought you had *not*, because when I looked up your login on ranger
> >>>>> ("finger yuechen") it said "never logged in". But seems like that info
> >>>>> is incorrect.
> >>>>> If you have ptmap compiled, seems like you are almost all set.
> >>>>> Let me know if it works.
> >>>>> - Mike
> >>>>>  > Thanks!
> >>>>>  > Chen, Yue
> >>>>>  > *Sent:* Thu 4/30/2009 1:07 PM
> >>>>>  > *Cc:* swift user
> >>>>>  > Yue, use this XML pool element to access ranger:
> >>>>>  >      <gridftp
> >>>>>  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
> >>>>>  >    </pool>
> >>>>>  > You will need to also do these steps:
> >>>>>  > Go to this web page to enable your Ranger account:
> >>>>>  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
> >>>>>  > Then login to Ranger via the TeraGrid portal and put your ssh
> >>>>> keys in
> >>>>>  > place (assuming you use ssh keys, which you should)
> >>>>>  > While on Ranger, do this:
> >>>>>  > echo $WORK
> >>>>>  > mkdir $work/swiftwork
> >>>>>  > and put the full path of your $WORK/swiftwork directory in the
> >>>>>  > <workdirectory> element above. (My login is tg455etc, yours is
> >>>> yuechen)
> >>>>>  > Then scp your code to Ranger and compile it.
> >>>>>  > Then create a tc.data entry for your ptmap app
> >>>>>  > Next, set your time values in the sites.xml entry above to suitable
> >>>>>  > values for Ranger. You'll need to measure times, but I think you
> >>>>> will
> >>>>>  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
> >>>>>  > The values above were set for one app job per coaster. I think
> >>>> you can
> >>>>>  > probably do more.
> >>>>>  > If you estimate a run time of 5 minutes, use:
> >>>>>  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
> >>>>>  >      <profile namespace="globus" key="maxwalltime">5</profile>
> >>>>>  > Other people on the list - please sanity check what I suggest here.
> >>>>>  > - Mike
> >>>>>  > On 4/30/09 12:40 PM, Michael Wilde wrote:
> >>>>>  >  > I just checked - TG-CDA070002T has indeed expired.
> >>>>>  >  > The best for now is to move to use (only) Ranger, under this
> >>>> account:
> >>>>>  >  > TG-CCR080022N
> >>>>>  >  > I will locate and send you a sites.xml entry in a moment.
> >>>>>  >  > You need to go to a web page to activate your Ranger login.
> >>>>>  >  > Best to contact me in IM and we can work this out.
> >>>>>  >  > - Mike
> >>>>>  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
> >>>>>  >  >> Also, what account are you running under? We may need to change
> >>>>> you to
> >>>>>  >  >> a new account - as the OSG Training account expires today.
> >>>>>  >  >> If that happend at Noon, it *might* be the problem.
> >>>>>  >  >> - Mike
> >>>>>  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
> >>>>>  >  >>> Hi,
> >>>>>  >  >>> I came back to re-run my application on NCSA Mercury which was
> >>>>> tested
> >>>>>  >  >>> successfully last week after I just set up coasters with
> >>>> swift 0.9,
> >>>>>  >  >>> but I got many messages like the following:
> >>>>>  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
> >>>>>  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
> >>>>> but can
> >>>>>  >  >>> retry:1
> >>>>>  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556 Failed
> >>>> but can
> >>>>>  >  >>> retry:4
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
> >>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
> >>>>>  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
> >>>>> retry:8
> >>>>>  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
> >>>>>  >  >>> The log file for the successful run last week is ;
> >>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
> >>>>>  >  >>> The log file for the failed run is :
> >>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
> >>>>>  >  >>> I don't think I did anything different, so I don't know why
> >>>>> this
> >>>>> time
> >>>>>  >  >>> they failed. The sites.xml for Mercury is:
> >>>>>  >  >>>  <pool handle="NCSA_MERCURY">
> >>>>>  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
> >>>> url="grid-hg.ncsa.teragrid.org"
> >>>>>  >  >>> jobManager="gt2:PBS"/>
> >>>> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
> >>>>>  >  >>>     <profile namespace="globus" key="queue">debug</profile>
> >>>>>  >  >>>  </pool>
> >>>>>  >  >>> Thank you for help!
> >>>>>  >  >>> Chen, Yue
> >>>>>  >  >>> This email is intended only for the use of the individual or
> >>>> entity
> >>>>>  >  >>> to which it is addressed and may contain information that is
> >>>>>  >  >>> privileged and confidential. If the reader of this email
> >>>> message is
> >>>>>  >  >>> not the intended recipient, you are hereby notified that any
> >>>>>  >  >>> dissemination, distribution, or copying of this
> >>>>> communication is
> >>>>>  >  >>> prohibited. If you have received this email in error, please
> >>>> notify
> >>>>>  >  >>> the sender and destroy/delete all copies of the transmittal.
> >>>>> Thank you.
> >>>>>  >  >>> _______________________________________________
> >>>>>  >  >>> Swift-user mailing list
> >>>>>  >  >>> Swift-user at ci.uchicago.edu
> >>>>>  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> >>>> entity to
> >>>> privileged and
> >>>>>  > confidential. If the reader of this email message is not the
> >>>>> intended
> >>>>>  > recipient, you are hereby notified that any dissemination,
> >>>> distribution,
> >>>>>  > or copying of this communication is prohibited. If you have
> >>>>> received
> >>>>>  > this email in error, please notify the sender and destroy/delete
> >>>>> all
> >>>>>  > copies of the transmittal. Thank you.
> >>>>> This email is intended only for the use of the individual or entity to
> >>>>> privileged and
> >>>>> confidential. If the reader of this email message is not the intended
> >>>>> distribution,
> >>>>> or copying of this communication is prohibited. If you have received
> >>>>> this email in error, please notify the sender and destroy/delete all
> >>>> privileged and confidential. If the reader of this email message is
> >>>> dissemination, distribution, or copying of this communication is
> >>>> prohibited. If you have received this email in error, please notify
> >>>> the sender and destroy/delete all copies of the transmittal. Thank you.
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
