[Swift-devel] RE: [Swift-user] Execution error
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 30 17:23:56 CDT 2009
On 4/30/09 5:13 PM, Mihael Hategan wrote:
 >> GRAM Job submission failed because the job manager failed to open
stderr
 >> (error code 74)
 > That seems like an IP address problem. Make sure you set GLOBUS_HOSTNAME
 > properly.
OK, I will try that. But in the test below, I caused the error by
unsetting X509_CERT_DIR and fixed the error by resetting it - no other
changes.
I *think* that as recently as a few weeks ago globus-job-run to ranger
worked with just @globus in my .soft file.
Adding +osg-client seemed to make it work by setting X509_CERT_DIR.
So as far as I can tell, at least at the level of globus-job-run, these
seems to be related to certs.
Given what Im seeing, do you still think GLOBUS_HOSTNAME is a factor?
- Mike
> On Thu, 2009-04-30 at 17:01 -0500, Michael Wilde wrote:
>> A bit more info on this: it *seems* like a cert issue.
>> I last accessed Ranger via globus-job-run perhaps 2 weeks ago, no problem.
>> Yesterday, while debugging with Glen, globus-job-run was giving me GRAM
>> err 74. (and GRM err 12 to all other sites)
>> So I added +osg-client to my .soft file, and then globus-job-run worked.
>> But I noticed that my globus-job-run was still coming from the GT4 dir,
>> not from an OSG dir.
>> Just now I traced this back to X509_CERT_DIR:
>> <works here>  then I did:
>> com$ unset X509_CERT_DIR
>> com$ globus-job-run gatekeeper.ranger.tacc.teragrid.org /usr/bin/id
>> GRAM Job submission failed because the job manager failed to open stderr
>> (error code 74)
> properly.
>> com$
>> com$
>> com$ X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
>> (error code 74)
>> com$ export X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
>> uid=455797(tg455797) gid=80243(G-80243)
>> groups=80243(G-80243),81031(G-81031),81411(G-81411),81611(G-81611),81613(G-81613),81621(G-81621),81747(G-81747),81792(G-81792),800744(G-800744),800745(G-800745),800889(G-800889),800981(G-800981),800983(G-800983),801271(G-801271),801364(G-801364)
>> com$
>> Mihael, does swift honor X509_CERT_DIR? If so, Glen, Yue, that is
>> something to try.
>> You may need to put +osg-client this in your .soft file and re-login:
>> @python-2.5
>> +java-sun
>> +apache-ant
>> +gx-map
>> +condor
>> +gx-map
>> @globus-4
>> @default
>> +R
>> +torque
>> +maui
>> +matlab-7.7
>> +osg-client
>> - Mike
>> On 4/30/09 4:39 PM, Michael Wilde wrote:
>>> And we should also drill back down to why (at least yesterday) the GT4
>>> softev package failed, but the OSG client worked, for globus-job-run.
>>> I guess its possible there is a host or CA cert issue here.
>>> - Mike
>>> On 4/30/09 4:31 PM, Mihael Hategan wrote:
>>>> Can you guys try to run first.swift on ranger with the settings you have
>>>> (you'll need to add "echo" to tc.data)?
>>>> On Thu, 2009-04-30 at 16:13 -0500, Glen Hocky wrote:
>>>>> I have the identical response on ranger. It started yesterday
>>>>> evening. Possibly a problem that the TACC folks need to fix?
>>>>> Glen
>>>>> Yue, Chen - BMD wrote:
>>>>>> Hi Michael,
>>>>>> Thank you for the advices. I tested ranger with 1 job and new
>>>>>> specifications of maxwalltime. It shows the following error message.
>>>>>> I don't know if there is other problem with my setup. Thank you!
>>>>>> [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file
>>>>>> sites.xml -tc.file tc.data
>>>>>> Swift 0.9rc2 swift-r2860 cog-r2388
>>>>>> RunID: 20090430-1559-2vi6x811
>>>>>> Progress:
>>>>>> Progress:  Stage in:1
>>>>>> Progress:  Submitting:1
>>>>>> Progress:  Submitted:1
>>>>>> Progress:  Active:1
>>>>>> Failed to transfer wrapper log from
>>>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
>>>>>> Progress:  Active:1
>>>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
>>>>>> Progress:  Active:1
>>>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
>>>>>> Progress:  Failed:1
>>>>>> Execution failed:
>>>>>>         Exception in PTMap2:
>>>>>> Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
>>>>>> parameters.txt]
>>>>>> Host: ranger
>>>>>> Directory: PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
>>>>>> stderr.txt:
>>>>>> stdout.txt:
>>>>>> Caused by:
>>>>>>         Failed to start worker:
>>>>>> null
>>>>>> null
>>>>>> org.globus.gram.GramException: The job manager detected an invalid
>>>>>> script response
>>>>>>         at
>>>>>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>>>>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>>>>>         at
>>>>>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>>>>>         at java.lang.Thread.run(Thread.java:619)
>>>>>> Cleaning up...
>>>>>> Shutting down service at https://129.114.50.163:45562
>>>>>> <https://129.114.50.163:45562>
>>>>>> Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
>>>>>> - Done
>>>>>> Chen, Yue
>>>>>> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
>>>>>> *Sent:* Thu 4/30/2009 3:02 PM
>>>>>> *To:* Yue, Chen - BMD; swift-devel
>>>>>> *Subject:* Re: [Swift-user] Execution error
>>>>>> Back on list here (I only went off-list to discuss accounts, etc)
>>>>>> The problem in the run below is this:
>>>>>> 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
>>>>>> jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
>>>>>> the given max walltime worker constraint (task: 3000, \
>>>>>> maxwalltime: 2400s)
>>>>>> You have this on the ptmap app in your tc.data:
>>>>>> globus::maxwalltime=50
>>>>>> But you only gave coasters 40 mins per coaster worker. So its
>>>>>> complaining that it cant run a 50 minute job in a 40 minute (max)
>>>>>> coaster worker. ;)
>>>>>> I mentioned in a prior mail that you need to set the two time vals in
>>>>>> your sites.xml entry; thats what you need to do next, now.
>>>>>> change the coaster time in your sites.xml to:
>>>>>>      key="coasterWorkerMaxwalltime">00:51:00</profile>
>>>>>> If you have more info on the variability of your ptmap run times, send
>>>>>> that to the list, and we can discuss how to handle.
>>>>>> (NOTE: doing grp -i of the log for "except" or scanning for "except"
>>>>>> with an editor will often locate the first "exception" that your job
>>>>>> encountered. Thats how I found the error above).
>>>>>> Also, Yue, for testing new sites, or for validating that old sites
>>>>>> still
>>>>>> work, you should create the smallest possible ptmap workflow - 1 job if
>>>>>> that is possible - and verify that this works.  Then say 10 jobs to
>>>>>> make
>>>>>> sure scheduling etc is sane.  Then, send in your huge jobs.
>>>>>> With only 1 job, its easier to spot the errors in the log file.
>>>>>> - Mike
>>>>>> On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
>>>>>>> Hi Michael,
>>>>>>> I run into the same messages again when I use Ranger:
>>>>>>> Progress:  Selecting site:146  Stage in:25  Submitting:15
>>>>>>> Submitted:821
>>>>>>> Failed but can retry:16
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
>>>>>>> Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
>>>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
>>>>>>> The log for the search is at :
>>>>>>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
>>>>>>> The sites.xml I have is:
>>>>>>>  <pool handle="ranger">
>>>>>>>      <execution provider="coaster"
>>>>>>>                 url="gatekeeper.ranger.tacc.teragrid.org"
>>>>>>>                 jobManager="gt2:gt2:SGE"/>
>>>>>>>      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
>>>>>>>      <profile namespace="env"
>>>>>>>               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
>>>>>>>      <profile namespace="globus" key="project">TG-CCR080022N</profile>
>>>>>>>      <profile namespace="globus" key="coastersPerNode">16</profile>
>>>>>>>      <profile namespace="globus" key="queue">development</profile>
>>>>>>>               key="coasterWorkerMaxwalltime">00:40:00</profile>
>>>>>>>      <profile namespace="globus" key="maxwalltime">31</profile>
>>>>>>>      <profile namespace="karajan" key="initialScore">50</profile>
>>>>>>>      <profile namespace="karajan" key="jobThrottle">10</profile>
>>>>>>>      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
>>>>>>>  </pool>
>>>>>>> The tc.data I have is:
>>>>>>> ranger          PTMap2
>>>>>>> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED
>>>>>>> INTEL32::LINUX  globus::maxwalltime=50
>>>>>>> I'm using swift 0.9 rc2
>>>>>>> Thank you very much for help!
>>>>>>> Chen, Yue
>>>>>>> *Sent:* Thu 4/30/2009 2:05 PM
>>>>>>> On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
>>>>>>>  > Hi Michael,
>>>>>>>  > When I tried to activate my account, I encountered the following
>>>>>> error:
>>>>>>>  > "Sorry, this account is in an invalid state. You may not activate
>>>>>> your
>>>>>>>  > at this time."
>>>>>>>  > I used the username and password from TG-CDA070002T. Should I use a
>>>>>>>  > different password?
>>>>>>> If you can already login to Ranger, then you are all set - you must
>>>>>>> have
>>>>>>> done this previously.
>>>>>>> I thought you had *not*, because when I looked up your login on ranger
>>>>>>> ("finger yuechen") it said "never logged in". But seems like that info
>>>>>>> is incorrect.
>>>>>>> If you have ptmap compiled, seems like you are almost all set.
>>>>>>> Let me know if it works.
>>>>>>> - Mike
>>>>>>>  > Thanks!
>>>>>>>  > Chen, Yue
>>>>>>>  > *Sent:* Thu 4/30/2009 1:07 PM
>>>>>>>  > *Cc:* swift user
>>>>>>>  > Yue, use this XML pool element to access ranger:
>>>>>>>  >      <gridftp
>>>>>>>  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
>>>>>>>  >    </pool>
>>>>>>>  > You will need to also do these steps:
>>>>>>>  > Go to this web page to enable your Ranger account:
>>>>>>>  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
>>>>>>>  > Then login to Ranger via the TeraGrid portal and put your ssh
>>>>>>> keys in
>>>>>>>  > place (assuming you use ssh keys, which you should)
>>>>>>>  > While on Ranger, do this:
>>>>>>>  > echo $WORK
>>>>>>>  > mkdir $work/swiftwork
>>>>>>>  > and put the full path of your $WORK/swiftwork directory in the
>>>>>>>  > <workdirectory> element above. (My login is tg455etc, yours is
>>>>>> yuechen)
>>>>>>>  > Then scp your code to Ranger and compile it.
>>>>>>>  > Then create a tc.data entry for your ptmap app
>>>>>>>  > Next, set your time values in the sites.xml entry above to suitable
>>>>>>>  > values for Ranger. You'll need to measure times, but I think you
>>>>>>> will
>>>>>>>  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
>>>>>>>  > The values above were set for one app job per coaster. I think
>>>>>> you can
>>>>>>>  > probably do more.
>>>>>>>  > If you estimate a run time of 5 minutes, use:
>>>>>>>  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
>>>>>>>  >      <profile namespace="globus" key="maxwalltime">5</profile>
>>>>>>>  > Other people on the list - please sanity check what I suggest here.
>>>>>>>  > - Mike
>>>>>>>  > On 4/30/09 12:40 PM, Michael Wilde wrote:
>>>>>>>  >  > I just checked - TG-CDA070002T has indeed expired.
>>>>>>>  >  > The best for now is to move to use (only) Ranger, under this
>>>>>> account:
>>>>>>>  >  > TG-CCR080022N
>>>>>>>  >  > I will locate and send you a sites.xml entry in a moment.
>>>>>>>  >  > You need to go to a web page to activate your Ranger login.
>>>>>>>  >  > Best to contact me in IM and we can work this out.
>>>>>>>  >  > - Mike
>>>>>>>  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
>>>>>>>  >  >> Also, what account are you running under? We may need to change
>>>>>>> you to
>>>>>>>  >  >> a new account - as the OSG Training account expires today.
>>>>>>>  >  >> If that happend at Noon, it *might* be the problem.
>>>>>>>  >  >> - Mike
>>>>>>>  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
>>>>>>>  >  >>> Hi,
>>>>>>>  >  >>> I came back to re-run my application on NCSA Mercury which was
>>>>>>> tested
>>>>>>>  >  >>> successfully last week after I just set up coasters with
>>>>>> swift 0.9,
>>>>>>>  >  >>> but I got many messages like the following:
>>>>>>>  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
>>>>>>>  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
>>>>>>> but can
>>>>>>>  >  >>> retry:1
>>>>>>>  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556 Failed
>>>>>> but can
>>>>>>>  >  >>> retry:4
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
>>>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
>>>>>>>  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
>>>>>>> retry:8
>>>>>>>  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
>>>>>>>  >  >>> The log file for the successful run last week is ;
>>>>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
>>>>>>>  >  >>> The log file for the failed run is :
>>>>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
>>>>>>>  >  >>> I don't think I did anything different, so I don't know why
>>>>>>> this
>>>>>>> time
>>>>>>>  >  >>> they failed. The sites.xml for Mercury is:
>>>>>>>  >  >>>  <pool handle="NCSA_MERCURY">
>>>>>>>  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
>>>>>> url="grid-hg.ncsa.teragrid.org"
>>>>>>>  >  >>> jobManager="gt2:PBS"/>
>>>>>> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
>>>>>>>  >  >>>     <profile namespace="globus" key="queue">debug</profile>
>>>>>>>  >  >>>  </pool>
>>>>>>>  >  >>> Thank you for help!
>>>>>>>  >  >>> Chen, Yue
>>>>>>>  >  >>> This email is intended only for the use of the individual or
>>>>>> entity
>>>>>>>  >  >>> to which it is addressed and may contain information that is
>>>>>>>  >  >>> privileged and confidential. If the reader of this email
>>>>>> message is
>>>>>>>  >  >>> not the intended recipient, you are hereby notified that any
>>>>>>>  >  >>> dissemination, distribution, or copying of this
>>>>>>> communication is
>>>>>>>  >  >>> prohibited. If you have received this email in error, please
>>>>>> notify
>>>>>>>  >  >>> the sender and destroy/delete all copies of the transmittal.
>>>>>>> Thank you.
>>>>>>>  >  >>> _______________________________________________
>>>>>>>  >  >>> Swift-user mailing list
>>>>>>>  >  >>> Swift-user at ci.uchicago.edu
>>>>>>>  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>>>>>> entity to
>>>>>> privileged and
>>>>>>>  > confidential. If the reader of this email message is not the
>>>>>>> intended
>>>>>>>  > recipient, you are hereby notified that any dissemination,
>>>>>> distribution,
>>>>>>>  > or copying of this communication is prohibited. If you have
>>>>>>> received
>>>>>>>  > this email in error, please notify the sender and destroy/delete
>>>>>>> all
>>>>>>>  > copies of the transmittal. Thank you.
>>>>>>> This email is intended only for the use of the individual or entity to
>>>>>>> privileged and
>>>>>>> confidential. If the reader of this email message is not the intended
>>>>>>> distribution,
>>>>>>> or copying of this communication is prohibited. If you have received
>>>>>>> this email in error, please notify the sender and destroy/delete all
>>>>>> privileged and confidential. If the reader of this email message is
>>>>>> dissemination, distribution, or copying of this communication is
>>>>>> prohibited. If you have received this email in error, please notify
>>>>>> the sender and destroy/delete all copies of the transmittal. Thank you.
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
