[Swift-devel] RE: [Swift-user] Execution error
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 30 17:01:45 CDT 2009
A bit more info on this: it *seems* like a cert issue.
I last accessed Ranger via globus-job-run perhaps 2 weeks ago, no problem.
Yesterday, while debugging with Glen, globus-job-run was giving me GRAM
err 74. (and GRM err 12 to all other sites)
So I added +osg-client to my .soft file, and then globus-job-run worked.
But I noticed that my globus-job-run was still coming from the GT4 dir,
not from an OSG dir.
Just now I traced this back to X509_CERT_DIR:
<works here>  then I did:
com$ unset X509_CERT_DIR
com$ globus-job-run gatekeeper.ranger.tacc.teragrid.org /usr/bin/id
GRAM Job submission failed because the job manager failed to open stderr
(error code 74)
com$
com$
com$ X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
(error code 74)
com$ export X509_CERT_DIR=/soft/osg-client-1.0.0-r1/globus/TRUSTED_CA
uid=455797(tg455797) gid=80243(G-80243)
groups=80243(G-80243),81031(G-81031),81411(G-81411),81611(G-81611),81613(G-81613),81621(G-81621),81747(G-81747),81792(G-81792),800744(G-800744),800745(G-800745),800889(G-800889),800981(G-800981),800983(G-800983),801271(G-801271),801364(G-801364)
com$
Mihael, does swift honor X509_CERT_DIR? If so, Glen, Yue, that is
something to try.
You may need to put +osg-client this in your .soft file and re-login:
@python-2.5
+java-sun
+apache-ant
+gx-map
+condor
+gx-map
@globus-4
@default
+R
+torque
+maui
+matlab-7.7
+osg-client
- Mike
On 4/30/09 4:39 PM, Michael Wilde wrote:
> And we should also drill back down to why (at least yesterday) the GT4
> softev package failed, but the OSG client worked, for globus-job-run.
> I guess its possible there is a host or CA cert issue here.
> - Mike
> On 4/30/09 4:31 PM, Mihael Hategan wrote:
>> Can you guys try to run first.swift on ranger with the settings you have
>> (you'll need to add "echo" to tc.data)?
>> On Thu, 2009-04-30 at 16:13 -0500, Glen Hocky wrote:
>>> I have the identical response on ranger. It started yesterday
>>> evening. Possibly a problem that the TACC folks need to fix?
>>> Glen
>>> Yue, Chen - BMD wrote:
>>>> Hi Michael,
>>>> Thank you for the advices. I tested ranger with 1 job and new
>>>> specifications of maxwalltime. It shows the following error message.
>>>> I don't know if there is other problem with my setup. Thank you!
>>>> [yuechen at communicado PTMap2]$ swift PTMap2-unmod.swift -sites.file
>>>> sites.xml -tc.file tc.data
>>>> Swift 0.9rc2 swift-r2860 cog-r2388
>>>> RunID: 20090430-1559-2vi6x811
>>>> Progress:
>>>> Progress:  Stage in:1
>>>> Progress:  Submitting:1
>>>> Progress:  Submitted:1
>>>> Progress:  Active:1
>>>> Failed to transfer wrapper log from
>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/i on ranger
>>>> Progress:  Active:1
>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/k on ranger
>>>> Progress:  Active:1
>>>> PTMap2-unmod-20090430-1559-2vi6x811/info/m on ranger
>>>> Progress:  Failed:1
>>>> Execution failed:
>>>>         Exception in PTMap2:
>>>> Arguments: [e04.mzXML, ./seqs-ecolik12/fasta01, inputs-unmod.txt,
>>>> parameters.txt]
>>>> Host: ranger
>>>> Directory: PTMap2-unmod-20090430-1559-2vi6x811/jobs/m/PTMap2-mbe6m5aj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>>         Failed to start worker:
>>>> null
>>>> null
>>>> org.globus.gram.GramException: The job manager detected an invalid
>>>> script response
>>>>         at
>>>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>>>         at
>>>> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>>>         at java.lang.Thread.run(Thread.java:619)
>>>> Cleaning up...
>>>> Shutting down service at https://129.114.50.163:45562
>>>> <https://129.114.50.163:45562>
>>>> Got channel MetaChannel: 20903429 -> GSSSChannel-null(1)
>>>> - Done
>>>> Chen, Yue
>>>> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
>>>> *Sent:* Thu 4/30/2009 3:02 PM
>>>> *To:* Yue, Chen - BMD; swift-devel
>>>> *Subject:* Re: [Swift-user] Execution error
>>>> Back on list here (I only went off-list to discuss accounts, etc)
>>>> The problem in the run below is this:
>>>> 2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
>>>> jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
>>>> the given max walltime worker constraint (task: 3000, \
>>>> maxwalltime: 2400s)
>>>> You have this on the ptmap app in your tc.data:
>>>> globus::maxwalltime=50
>>>> But you only gave coasters 40 mins per coaster worker. So its
>>>> complaining that it cant run a 50 minute job in a 40 minute (max)
>>>> coaster worker. ;)
>>>> I mentioned in a prior mail that you need to set the two time vals in
>>>> your sites.xml entry; thats what you need to do next, now.
>>>> change the coaster time in your sites.xml to:
>>>>      key="coasterWorkerMaxwalltime">00:51:00</profile>
>>>> If you have more info on the variability of your ptmap run times, send
>>>> that to the list, and we can discuss how to handle.
>>>> (NOTE: doing grp -i of the log for "except" or scanning for "except"
>>>> with an editor will often locate the first "exception" that your job
>>>> encountered. Thats how I found the error above).
>>>> Also, Yue, for testing new sites, or for validating that old sites
>>>> still
>>>> work, you should create the smallest possible ptmap workflow - 1 job if
>>>> that is possible - and verify that this works.  Then say 10 jobs to
>>>> make
>>>> sure scheduling etc is sane.  Then, send in your huge jobs.
>>>> With only 1 job, its easier to spot the errors in the log file.
>>>> - Mike
>>>> On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
>>>>> Hi Michael,
>>>>> I run into the same messages again when I use Ranger:
>>>>> Progress:  Selecting site:146  Stage in:25  Submitting:15
>>>>> Submitted:821
>>>>> Failed but can retry:16
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
>>>>> Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
>>>>> PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
>>>>> The log for the search is at :
>>>>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
>>>>> The sites.xml I have is:
>>>>>  <pool handle="ranger">
>>>>>      <execution provider="coaster"
>>>>>                 url="gatekeeper.ranger.tacc.teragrid.org"
>>>>>                 jobManager="gt2:gt2:SGE"/>
>>>>>      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
>>>>>      <profile namespace="env"
>>>>>               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
>>>>>      <profile namespace="globus" key="project">TG-CCR080022N</profile>
>>>>>      <profile namespace="globus" key="coastersPerNode">16</profile>
>>>>>      <profile namespace="globus" key="queue">development</profile>
>>>>>               key="coasterWorkerMaxwalltime">00:40:00</profile>
>>>>>      <profile namespace="globus" key="maxwalltime">31</profile>
>>>>>      <profile namespace="karajan" key="initialScore">50</profile>
>>>>>      <profile namespace="karajan" key="jobThrottle">10</profile>
>>>>>      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
>>>>>  </pool>
>>>>> The tc.data I have is:
>>>>> ranger          PTMap2
>>>>> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED
>>>>> INTEL32::LINUX  globus::maxwalltime=50
>>>>> I'm using swift 0.9 rc2
>>>>> Thank you very much for help!
>>>>> Chen, Yue
>>>>> *Sent:* Thu 4/30/2009 2:05 PM
>>>>> On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
>>>>>  > Hi Michael,
>>>>>  > When I tried to activate my account, I encountered the following
>>>> error:
>>>>>  > "Sorry, this account is in an invalid state. You may not activate
>>>> your
>>>>>  > at this time."
>>>>>  > I used the username and password from TG-CDA070002T. Should I use a
>>>>>  > different password?
>>>>> If you can already login to Ranger, then you are all set - you must
>>>>> have
>>>>> done this previously.
>>>>> I thought you had *not*, because when I looked up your login on ranger
>>>>> ("finger yuechen") it said "never logged in". But seems like that info
>>>>> is incorrect.
>>>>> If you have ptmap compiled, seems like you are almost all set.
>>>>> Let me know if it works.
>>>>> - Mike
>>>>>  > Thanks!
>>>>>  > Chen, Yue
>>>>>  > *Sent:* Thu 4/30/2009 1:07 PM
>>>>>  > *Cc:* swift user
>>>>>  > Yue, use this XML pool element to access ranger:
>>>>>  >      <gridftp
>>>>>  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
>>>>>  >    </pool>
>>>>>  > You will need to also do these steps:
>>>>>  > Go to this web page to enable your Ranger account:
>>>>>  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
>>>>>  > Then login to Ranger via the TeraGrid portal and put your ssh
>>>>> keys in
>>>>>  > place (assuming you use ssh keys, which you should)
>>>>>  > While on Ranger, do this:
>>>>>  > echo $WORK
>>>>>  > mkdir $work/swiftwork
>>>>>  > and put the full path of your $WORK/swiftwork directory in the
>>>>>  > <workdirectory> element above. (My login is tg455etc, yours is
>>>> yuechen)
>>>>>  > Then scp your code to Ranger and compile it.
>>>>>  > Then create a tc.data entry for your ptmap app
>>>>>  > Next, set your time values in the sites.xml entry above to suitable
>>>>>  > values for Ranger. You'll need to measure times, but I think you
>>>>> will
>>>>>  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
>>>>>  > The values above were set for one app job per coaster. I think
>>>> you can
>>>>>  > probably do more.
>>>>>  > If you estimate a run time of 5 minutes, use:
>>>>>  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
>>>>>  >      <profile namespace="globus" key="maxwalltime">5</profile>
>>>>>  > Other people on the list - please sanity check what I suggest here.
>>>>>  > - Mike
>>>>>  > On 4/30/09 12:40 PM, Michael Wilde wrote:
>>>>>  >  > I just checked - TG-CDA070002T has indeed expired.
>>>>>  >  > The best for now is to move to use (only) Ranger, under this
>>>> account:
>>>>>  >  > TG-CCR080022N
>>>>>  >  > I will locate and send you a sites.xml entry in a moment.
>>>>>  >  > You need to go to a web page to activate your Ranger login.
>>>>>  >  > Best to contact me in IM and we can work this out.
>>>>>  >  > - Mike
>>>>>  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
>>>>>  >  >> Also, what account are you running under? We may need to change
>>>>> you to
>>>>>  >  >> a new account - as the OSG Training account expires today.
>>>>>  >  >> If that happend at Noon, it *might* be the problem.
>>>>>  >  >> - Mike
>>>>>  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
>>>>>  >  >>> Hi,
>>>>>  >  >>> I came back to re-run my application on NCSA Mercury which was
>>>>> tested
>>>>>  >  >>> successfully last week after I just set up coasters with
>>>> swift 0.9,
>>>>>  >  >>> but I got many messages like the following:
>>>>>  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
>>>>>  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
>>>>> but can
>>>>>  >  >>> retry:1
>>>>>  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556 Failed
>>>> but can
>>>>>  >  >>> retry:4
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
>>>>>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
>>>>>  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
>>>>> retry:8
>>>>>  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
>>>>>  >  >>> The log file for the successful run last week is ;
>>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
>>>>>  >  >>> The log file for the failed run is :
>>>>>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
>>>>>  >  >>> I don't think I did anything different, so I don't know why
>>>>> this
>>>>> time
>>>>>  >  >>> they failed. The sites.xml for Mercury is:
>>>>>  >  >>>  <pool handle="NCSA_MERCURY">
>>>>>  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
>>>> url="grid-hg.ncsa.teragrid.org"
>>>>>  >  >>> jobManager="gt2:PBS"/>
>>>> <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
>>>>>  >  >>>     <profile namespace="globus" key="queue">debug</profile>
>>>>>  >  >>>  </pool>
>>>>>  >  >>> Thank you for help!
>>>>>  >  >>> Chen, Yue
>>>>>  >  >>> This email is intended only for the use of the individual or
>>>> entity
>>>>>  >  >>> to which it is addressed and may contain information that is
>>>>>  >  >>> privileged and confidential. If the reader of this email
>>>> message is
>>>>>  >  >>> not the intended recipient, you are hereby notified that any
>>>>>  >  >>> dissemination, distribution, or copying of this
>>>>> communication is
>>>>>  >  >>> prohibited. If you have received this email in error, please
>>>> notify
>>>>>  >  >>> the sender and destroy/delete all copies of the transmittal.
>>>>> Thank you.
>>>>>  >  >>> _______________________________________________
>>>>>  >  >>> Swift-user mailing list
>>>>>  >  >>> Swift-user at ci.uchicago.edu
>>>>>  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>>>> entity to
>>>> privileged and
>>>>>  > confidential. If the reader of this email message is not the
>>>>> intended
>>>>>  > recipient, you are hereby notified that any dissemination,
>>>> distribution,
>>>>>  > or copying of this communication is prohibited. If you have
>>>>> received
>>>>>  > this email in error, please notify the sender and destroy/delete
>>>>> all
>>>>>  > copies of the transmittal. Thank you.
>>>>> This email is intended only for the use of the individual or entity to
>>>>> privileged and
>>>>> confidential. If the reader of this email message is not the intended
>>>>> distribution,
>>>>> or copying of this communication is prohibited. If you have received
>>>>> this email in error, please notify the sender and destroy/delete all
>>>> privileged and confidential. If the reader of this email message is
>>>> dissemination, distribution, or copying of this communication is
>>>> prohibited. If you have received this email in error, please notify
>>>> the sender and destroy/delete all copies of the transmittal. Thank you.
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
