[Swift-devel] nearly, but not quite	optimal	performance	on	ranger from ranger under coasters
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Apr 30 00:07:31 CDT 2009
On Wed, 2009-04-29 at 23:59 -0500, Glen Hocky wrote:
> I definately have a nonexpired project in my sites file
How about what Mike says?
> Mihael Hategan wrote:
> > On Wed, 2009-04-29 at 23:10 -0500, Michael Wilde wrote:
> >> On 4/29/09 7:55 PM, Mihael Hategan wrote:
> >>> On Wed, 2009-04-29 at 19:40 -0500, Glen Hocky wrote:
> >>>> Tried to rerun (identical everything) but am now getting the errors in
> >>>> this logfile
> >>>>> /home/hockyg/public_html/swift_logs/ranger_from_ranger/oops-20090429-1920-q6r3oph1.log
> >>>> Errors are:
> >>> org.globus.gram.GramException: The job manager detected an invalid
> >>> script response
> >> I vaguely recall this error being causes when the job time exceeded the
> >> limits of the queue time, or some similar error.
> >> Look to see if you got PBS errors in your home dir, or clues in the gram
> >> logs on the target site.
> >> One case was that the calculated time needed for the coaster jobs
> >> exceeded the queue limit.
> > Could be.
> >> Of course, it could be something entirely different.
> >>> I'm getting the same when I do a simple job submission. Apparently gram
> >>> on ranger is broken again.
> >> Did you do this from communicado?
> > No. I did this from my own machine. Seems like I didn't specify a
> > project, and my default got screwed up. So Glen, check if you are using
> > an expired project, or whether you specify a project at all in
> > sites.xml.
