[Swift-devel] nearly, but not quite optimal	performance	on	ranger from ranger under coasters
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Apr 29 23:39:23 CDT 2009
On Wed, 2009-04-29 at 23:10 -0500, Michael Wilde wrote:
> On 4/29/09 7:55 PM, Mihael Hategan wrote:
> > On Wed, 2009-04-29 at 19:40 -0500, Glen Hocky wrote:
> >> Tried to rerun (identical everything) but am now getting the errors in
> >> this logfile
> >>> /home/hockyg/public_html/swift_logs/ranger_from_ranger/oops-20090429-1920-q6r3oph1.log
> >> Errors are:
> > org.globus.gram.GramException: The job manager detected an invalid
> > script response
> I vaguely recall this error being causes when the job time exceeded the
> limits of the queue time, or some similar error.
> Look to see if you got PBS errors in your home dir, or clues in the gram
> logs on the target site.
> One case was that the calculated time needed for the coaster jobs
> exceeded the queue limit.
Could be.
> Of course, it could be something entirely different.
> > I'm getting the same when I do a simple job submission. Apparently gram
> > on ranger is broken again.
> Did you do this from communicado?
No. I did this from my own machine. Seems like I didn't specify a
project, and my default got screwed up. So Glen, check if you are using
an expired project, or whether you specify a project at all in
sites.xml.
