[Swift-devel] Re: [Swift-user] Execution error
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 30 15:02:50 CDT 2009
Back on list here (I only went off-list to discuss accounts, etc)
The problem in the run below is this:
2009-04-30 14:29:41,265-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION
jobid=PTMap2-abeii5aj - Application exception: Job cannot be run with
the given max walltime worker constraint (task: 3000, \
maxwalltime: 2400s)
You have this on the ptmap app in your tc.data:
globus::maxwalltime=50
But you only gave coasters 40 mins per coaster worker. So its
complaining that it cant run a 50 minute job in a 40 minute (max)
coaster worker. ;)
I mentioned in a prior mail that you need to set the two time vals in
your sites.xml entry; thats what you need to do next, now.
change the coaster time in your sites.xml to:
     key="coasterWorkerMaxwalltime">00:51:00</profile>
If you have more info on the variability of your ptmap run times, send
that to the list, and we can discuss how to handle.
(NOTE: doing grp -i of the log for "except" or scanning for "except"
with an editor will often locate the first "exception" that your job
encountered. Thats how I found the error above).
Also, Yue, for testing new sites, or for validating that old sites still
work, you should create the smallest possible ptmap workflow - 1 job if
that is possible - and verify that this works.  Then say 10 jobs to make
sure scheduling etc is sane.  Then, send in your huge jobs.
With only 1 job, its easier to spot the errors in the log file.
- Mike
On 4/30/09 2:34 PM, Yue, Chen - BMD wrote:
> Hi Michael,
> I run into the same messages again when I use Ranger:
> Progress:  Selecting site:146  Stage in:25  Submitting:15  Submitted:821
> Failed but can retry:16
> Failed to transfer wrapper log from
> PTMap2-unmod-20090430-1428-v0c5di5c/info/q on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/l on ranger
> Progress:  Selecting site:146  Stage in:3  Submitting:1  Submitted:857
> PTMap2-unmod-20090430-1428-v0c5di5c/info/v on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/b on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/0 on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/a on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/8 on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/7 on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/4 on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/x on ranger
> PTMap2-unmod-20090430-1428-v0c5di5c/info/3 on ranger
> The log for the search is at :
> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1428-v0c5di5c.log
> The sites.xml I have is:
>  <pool handle="ranger">
>      <execution provider="coaster"
>                 url="gatekeeper.ranger.tacc.teragrid.org"
>                 jobManager="gt2:gt2:SGE"/>
>      <gridftp url="gsiftp://gridftp.ranger.tacc.teragrid.org:2811/" />
>      <profile namespace="env"
>               key="SWIFT_JOBDIR_PATH">/tmp/yuechen/jobdir</profile>
>      <profile namespace="globus" key="project">TG-CCR080022N</profile>
>      <profile namespace="globus" key="coastersPerNode">16</profile>
>      <profile namespace="globus" key="queue">development</profile>
>               key="coasterWorkerMaxwalltime">00:40:00</profile>
>      <profile namespace="globus" key="maxwalltime">31</profile>
>      <profile namespace="karajan" key="initialScore">50</profile>
>      <profile namespace="karajan" key="jobThrottle">10</profile>
>      <workdirectory>/work/01164/yuechen/swiftwork</workdirectory>
>  </pool>
> The tc.data I have is:
> ranger          PTMap2
> /share/home/01164/yuechen/PTMap2/PTMap2         INSTALLED
> INTEL32::LINUX  globus::maxwalltime=50
> I'm using swift 0.9 rc2
> Thank you very much for help!
> Chen, Yue
> *From:* Michael Wilde [mailto:wilde at mcs.anl.gov]
> *Sent:* Thu 4/30/2009 2:05 PM
> *To:* Yue, Chen - BMD
> *Subject:* Re: [Swift-user] Execution error
> On 4/30/09 1:51 PM, Yue, Chen - BMD wrote:
>  > Hi Michael,
>  > When I tried to activate my account, I encountered the following error:
>  > "Sorry, this account is in an invalid state. You may not activate your
>  > at this time."
>  > I used the username and password from TG-CDA070002T. Should I use a
>  > different password?
> If you can already login to Ranger, then you are all set - you must have
> done this previously.
> I thought you had *not*, because when I looked up your login on ranger
> ("finger yuechen") it said "never logged in". But seems like that info
> is incorrect.
> If you have ptmap compiled, seems like you are almost all set.
> Let me know if it works.
> - Mike
>  > Thanks!
>  > Chen, Yue
>  > *Sent:* Thu 4/30/2009 1:07 PM
>  > *Cc:* swift user
>  > Yue, use this XML pool element to access ranger:
>  >      <workdirectory>/work/00306/tg455797/swiftwork</workdirectory>
>  >    </pool>
>  > You will need to also do these steps:
>  > Go to this web page to enable your Ranger account:
>  > https://tas.tacc.utexas.edu/TASMigration/AccountActivation.aspx
>  > Then login to Ranger via the TeraGrid portal and put your ssh keys in
>  > place (assuming you use ssh keys, which you should)
>  > While on Ranger, do this:
>  > echo $WORK
>  > mkdir $work/swiftwork
>  > and put the full path of your $WORK/swiftwork directory in the
>  > <workdirectory> element above. (My login is tg455etc, yours is yuechen)
>  > Then scp your code to Ranger and compile it.
>  > Then create a tc.data entry for your ptmap app
>  > Next, set your time values in the sites.xml entry above to suitable
>  > values for Ranger. You'll need to measure times, but I think you will
>  > find Ranger about twice as fast as Mercury for CPU-bound jobs.
>  > The values above were set for one app job per coaster. I think you can
>  > probably do more.
>  > If you estimate a run time of 5 minutes, use:
>  >               key="coasterWorkerMaxwalltime">00:30:00</profile>
>  >      <profile namespace="globus" key="maxwalltime">5</profile>
>  > Other people on the list - please sanity check what I suggest here.
>  > - Mike
>  > On 4/30/09 12:40 PM, Michael Wilde wrote:
>  >  > I just checked - TG-CDA070002T has indeed expired.
>  >  > The best for now is to move to use (only) Ranger, under this account:
>  >  > TG-CCR080022N
>  >  > I will locate and send you a sites.xml entry in a moment.
>  >  > You need to go to a web page to activate your Ranger login.
>  >  > Best to contact me in IM and we can work this out.
>  >  > - Mike
>  >  > On 4/30/09 12:23 PM, Michael Wilde wrote:
>  >  >> Also, what account are you running under? We may need to change
> you to
>  >  >> a new account - as the OSG Training account expires today.
>  >  >> If that happend at Noon, it *might* be the problem.
>  >  >> - Mike
>  >  >> On 4/30/09 12:08 PM, Yue, Chen - BMD wrote:
>  >  >>> Hi,
>  >  >>> I came back to re-run my application on NCSA Mercury which was
> tested
>  >  >>> successfully last week after I just set up coasters with swift 0.9,
>  >  >>> but I got many messages like the following:
>  >  >>> Progress:  Stage in:219  Submitting:803  Submitted:1
>  >  >>> Progress:  Stage in:129  Submitting:703  Submitted:190 Failed
> but can
>  >  >>> retry:1
>  >  >>> Progress:  Stage in:38  Submitting:425  Submitted:556 Failed but can
>  >  >>> retry:4
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/h on NCSA_MERCURY
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/j on NCSA_MERCURY
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/p on NCSA_MERCURY
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/1 on NCSA_MERCURY
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/b on NCSA_MERCURY
>  >  >>> PTMap2-unmod-20090430-1203-r19dxq10/info/c on NCSA_MERCURY
>  >  >>> Progress:  Stage in:1  Submitted:1013  Active:1 Failed but can
> retry:8
>  >  >>> Progress:  Submitted:1011  Active:1 Failed but can retry:11
>  >  >>> The log file for the successful run last week is ;
>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090422-1216-4s3037gf.log
>  >  >>> The log file for the failed run is :
>  >  >>> /home/yuechen/PTMap2/PTMap2-unmod-20090430-1151-rf2uuhb7.log
>  >  >>> I don't think I did anything different, so I don't know why this
> time
>  >  >>> they failed. The sites.xml for Mercury is:
>  >  >>>  <pool handle="NCSA_MERCURY">
>  >  >>>     <gridftp url="gsiftp://gridftp-hg.ncsa.teragrid.org"/>
>  >  >>>     <execution provider="coaster" url="grid-hg.ncsa.teragrid.org"
>  >  >>> jobManager="gt2:PBS"/>
>  >  >>>     <workdirectory>/gpfs_scratch1/yuechen/swiftwork</workdirectory>
>  >  >>>     <profile namespace="globus" key="queue">debug</profile>
>  >  >>>  </pool>
>  >  >>> Thank you for help!
>  >  >>> Chen, Yue
>  >  >>> This email is intended only for the use of the individual or entity
>  >  >>> to which it is addressed and may contain information that is
>  >  >>> privileged and confidential. If the reader of this email message is
>  >  >>> not the intended recipient, you are hereby notified that any
>  >  >>> dissemination, distribution, or copying of this communication is
>  >  >>> prohibited. If you have received this email in error, please notify
>  >  >>> the sender and destroy/delete all copies of the transmittal.
> Thank you.
>  >  >>> _______________________________________________
>  >  >>> Swift-user mailing list
>  >  >>> Swift-user at ci.uchicago.edu
>  >  >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>  > This email is intended only for the use of the individual or entity to
>  > which it is addressed and may contain information that is privileged and
>  > confidential. If the reader of this email message is not the intended
>  > recipient, you are hereby notified that any dissemination, distribution,
>  > or copying of this communication is prohibited. If you have received
>  > this email in error, please notify the sender and destroy/delete all
>  > copies of the transmittal. Thank you.
